Corkills Abarth
Author Topic: DIY 6K oil change  (Read 480 times)
Dames
DIY 6K oil change
« on: January 23, 2012, 12:00:25 AM »
My SS is approaching its first 6000 mile oil change. As all that is required is an oil change with no service inspections etc will DIYing it void the warranty?
Opie will be supplying the correct quality oil (10w50 for an SS I gather) & filter so I can keep receipts as proof. I am qualified to maintain aircraft but have no certificates to change my car oil.
I have chosen Fuchs Titan Race Pro S 10W-50 Ester Synthetic Engine Oil as both Fuchs Opie served me well in my RX8.
What think you?
Paula
  • Some days it all gets a bit too much. . .
Re: DIY 6K oil change
« Reply #1 on: January 23, 2012, 07:37:33 AM »
Chances are that you make a better job of it than a lot of garages and you are extremely unlikely to damage the car and claim it came in that way. However most people when buying a car want to see a stamped service book and should the engine blow up you may be in trouble on your warantee, so really not an option if you plan to keep the car forever and certainly not part ex it.
Paula
Red A500, 17" 10 Spoke Alloys and Black Leather: It's very red and it goes vroooooom.
« Reply #2 on: January 23, 2012, 08:51:06 AM »
has to be a VAT registered garage doing the work to maintain the warranty :thumb:
Andrew
  • AGP Board Moderator
« Reply #3 on: January 23, 2012, 09:01:53 AM »
Not all garages are the same. They are plenty of good ones around  :thumb:
Hozepipe
« Reply #4 on: January 23, 2012, 11:20:30 AM »
Is that the correct oil for the A500SS?
Joe
« Reply #5 on: January 23, 2012, 11:32:30 AM »
Personally I'd stick to Selenia.
I did my own oil and filter change at 24k, my warranty remains intact. I used the correct parts.
Le Mans 2012... 31 days to go!
Joe
« Reply #6 on: January 23, 2012, 11:36:52 AM »
Actually, your's in an SS. Mine isn't and didn't require an oil and filter change at 24k or 6k (although it had one becasue it's running SS+ power), so I essentially gave it two extra oil changes than are officially required.
Your's is officially required at 6k, so personally, I'd take it to an Abarth dealership and ask for an oil and filter change (don't get sucked into having a low-mileage service). Should cost about £90 includung parts.
« Reply #7 on: January 23, 2012, 11:37:06 AM »
yours was an additional oil change joe, nothing to do with the warranty, on an SS its specified in the service schedule so it has to be a vat registered garage to preserve the warranty :thumb:
Joe
« Reply #8 on: January 23, 2012, 11:38:06 AM »
Yup - just realised that ^^^
Dames
« Reply #9 on: January 23, 2012, 11:53:56 AM »
according to the extra "500 Abarth Preparation kit" booklet that came with the car owners manual etc. It says SAE 10W50 synthetic lube is needed.
searching the forum backs this up (I think). Standard Abarth use 5W40.
Back on the subject of DIY oil change, surely changing a light bulb yourself is not too different to a oil CX, they are just consumable parts, that wont affect the warranty.
I know that if I call any official dealer, Abarth or Fiat they will want their £££ and want the car in to do the work.
Are there any horror stories Ref 500 SS engine failures? or is the lump quite robust?
I intend to keep the car past the warranty dates anyway. (2 years plus 1 exteded year I gather) so I will be DIYing eventually anyway.
Anyone else have thoughts? especially from experience.
Paula
« Reply #10 on: January 23, 2012, 11:58:03 AM »
Yes I do know that having owned cars for over 25 years, but I was just making the point that if you do it yourself there is less chance of problems assuming you know what you are doing.
Joe
« Reply #11 on: January 23, 2012, 12:01:59 PM »
I can't see how changing your own oil and filter could lead to any problems, assuming you use the recommended oil and correct filter, but whether a dealer will share that view should your engine go bang when you haven't got the required stamp in your service book is down to you to determine. Is it worth risking it?
corsa
« Reply #12 on: January 23, 2012, 12:07:26 PM »
Yours has some modifications (power) too, no?
Presumably that would be reason enough for the dealer not to support any warranty claims.
Joe
« Reply #13 on: January 23, 2012, 12:26:41 PM »
It does. I took the risk.  :thumb:
The warranty isn't invalidated as soon as you service the car yourself or modify the car, but if something breaks as a result of, or in relation to something the owner has done, they they can't expect Abarth to pay to fix it...
Prime example: When my car went in for it's 36k service the other week, it was found to have a leaky CV boot. This is nothing to with any of the mods I have made, and is a common fault, so is being fixed under warranty. However, there is some slight damage to the flexi-joint on my exhaust where it has made contact with the road at some point, but that's an aftermarket exhaust and I've lowered the car, so it's up to me to sort that...
SJH
« Reply #14 on: January 23, 2012, 12:27:41 PM »
The Abarth warranty is quite valuable.  Like most other insurers, they want to see compliance before they pay....
