Abarth has launched two new elaboration kits for the Abarth 500.
The first, the Kit Abarth 695 Brembo Koni, includes the contents of the Kit esseesse Koni, but adds two features taken from the Abarth 695 Tributo Ferrari. The kit includes four alloy wheels which mirror the design used on the Abarth 695 Tributo Ferrari, but are finished in a unique Matt Black colour, and supplied with 205/40 ZR17 tyres. The kit also includes Brembo Monobloc front callipers, matched with fully-floating front discs, which are both self-ventilating and cross-drilled to ensure maximum efficiency even under the most demanding conditions.
The Kit Abarth 695 Brembo Koni is available to order now with a retail price including fitting* of £4,650.
The second kit, the Kit Abarth Brembo, is designed to complement the Kit esseesse Koni. This kit includes the same Brembo Monobloc front callipers and fully-floating, self-ventilating and cross-drilled front brake discs as the Kit Abarth 695 Brembo Koni.
This kit must be fitted with either the Kit esseesse Koni, or the standard esseesse kit in conjunction with the Koni suspension upgrade.
The retail price for the Kit Abarth Brembo is £2,020 including fitting*.
Kit Abarth 695 Brembo Koni - Kit Contents (available for Abarth 500 Hatchback only)
• 160 bhp Power Upgrade
• Brembo front brake set with Monobloc brake callipers M4 x 40mm
• Floating front brake discs; cross-drilled and self-ventilated
• Specific mounting kit and brake hoses
• High Performance Brake Pads
• Rear brake discs cross-drilled
• Front and Rear KONI Dampers with FSD valve (Frequency Selective Damping)
• Upgraded suspension springs set
• Alloy Wheels with specific design as per Abarth 695 Tributo Ferrari 7" x 17" ET35 Finished with special Matte Black coating and fitted with 205/40 ZR17 tyres
• Air Filter "powered by BMC"
Kit Abarth Brembo - Kit Contents (available for Abarth 500 & Abarth 500C)
• Dedicated Packaging
* Prices may differ by dealer as labour rates vary by region.
