Corkills Abarth
Author Topic: Knocking noise  (Read 667 times)
Moots
Knocking noise
« on: January 11, 2012, 06:41:07 PM »
Another thread on knocking noises. . .
I've started getting a knocking noise when going over speed bumps, the front ends fine but the rear sounds like something is loose. I've checked the stuff under the boot (wheel repair) which was a bit loose but tightening it up made no difference. If I push down on the back of the car I don't get any noises it only seems to happen on speed bumps. Any ideas?
I don't have konis btw
BnW A500 red Stripes + mirrors, petals, Bonnet Scorpion, Now with added Koni's!
corsa
Re: Knocking noise
« Reply #1 on: January 11, 2012, 06:49:31 PM »
Just an idea:
You might want to give this thread a better, more descriptive name :P
Exhaust fix?
Repair kit in the boot fix?
Moots
Re: Knocking noise
« Reply #2 on: January 11, 2012, 09:40:05 PM »
Point being I don't know what's making the noise. So to say exhaust knocking noise would be daft tbh.
FrankV500
  • Now sold :(
Re: Knocking noise
« Reply #3 on: January 11, 2012, 10:33:31 PM »
Hey mate
It might need some WD40 on all the suspension bushes, try that first.
If its still there drive with the seats down, if its still there then get some one in the back when you go over bumps, it could be anything to be honest.
I get a creak and now i dont care i just drive the dam car and let the music or engine/exhaust noises overcome the other noises  ;D
GREY / RED STRIPES / CHEQ ROOF / MONZA / ESSESSEE'D MYSELF FROM SCRATCH / WHITE SS WHEELS / EIBACH PRO SPRINGS / RED LEATHER / CLIMATE
Re: Knocking noise
« Reply #4 on: January 11, 2012, 10:42:51 PM »
pick the car up and let its wheels dangle for an hour, works on AGP ;D
Yordan
  • 2012
Re: Knocking noise
« Reply #5 on: January 11, 2012, 10:50:11 PM »
What? Like an mans dangles :whistle:.
On the other hand take everything out even the carpet from the boot then may find what causing it.
Olly-Midd
Re: Knocking noise
« Reply #6 on: January 12, 2012, 12:51:24 AM »
Sounds stupid but it probably is the door locks. Exactly the same problem, thought my suspension was creaking then one day i sat quite low and could hear it was indeed coming from the door and not the rear of the car. Wd40'd the lock like a good'un and hey presto! Have to do it every other week or so but it stops it. Try white grease or 3in1 oil and that is a better lubricant. :thumb:
Doolahrock
Re: Knocking noise
« Reply #7 on: January 13, 2012, 07:49:22 AM »
Do you have the Monza fitted?  Apparently the clearances on that can be tight and can cause a knocking.  Drive with the seats down as well to make sure they aren't the problem.  Other than that I'm not sure.
Maser3200
Re: Knocking noise
« Reply #8 on: January 15, 2012, 04:13:13 PM »
Check both front and rear shock mountings. My fronts failed at 7,300 miles - well that's when it was spotted whilst changing worn front tyres.
Moots
Re: Knocking noise
« Reply #9 on: January 29, 2012, 02:34:36 PM »
Well, it's had the Koni's fitted and it's made no difference :( really doing my head in. It's more of a rattling noise than a knock.
Had the missus sit in the back and it's coming from both sides at the rear sounds like it might be coming from the wheel arches. No idea what it could be now :(
SJH
Re: Knocking noise
« Reply #10 on: January 29, 2012, 02:44:26 PM »
I was going to suggest the handbrake cable until you said both sides.  ???
retro
Re: Knocking noise
« Reply #11 on: January 29, 2012, 02:48:08 PM »
Have you tried the loop of insulating tape on the rear seats catch yet? Stopped one of my rattles. I also had a problem with the front passenger seat rattling once. Took me ages to locate that one, it can be hard to hear exactly where a noise is coming from. Fixed that with some packing foam underneath.
Abarth 500 LE with Koni Kit.
Moots
Re: Knocking noise
« Reply #12 on: January 29, 2012, 02:51:32 PM »
Think i'm going to have to get someone to look at it again, which means either driving around with it for a month when the service is booked or taking it to my local indy guy to have a look at. i wouldn't be bothered but it sounds like something is loose which is worrying me.
I've tried moving the exhaust but it seems solid, pushing down on the back of the car doesn't make any noise and i've taken the stuff out of the spare compartment which made no difference either. Also tried slamming the seats back into place.  ??? :-\
FWD_Boy
  • Gumball Racing
Re: Knocking noise
« Reply #13 on: January 29, 2012, 03:20:51 PM »
If the cars still under warrently just return it to the dealer and ask them to reslove the issue. Give them a bell and ask if it can be looked at as it could be something important it might be something simple like everybody has mentioned.
Wakeup73
Re: Knocking noise
« Reply #14 on: February 01, 2012, 02:00:16 PM »
OK, may sound daft but I have noticed where my "knock" is coming from.   My rear number plate has been secured by 2 screws at the far top right and left hand corners.
The number plate can now flap around at the bottom and it knocks against the tailgate.  Now, doesnt seem like much but when I close the tailgate the number plate makes a fair dunt noise as it slams against the metal of the boot.  I recognised the same noise going over speed bumps (slightly too fast) so knew the number plate was rattling away because of the way they have secured it.  it sounds worse from the inside and it knocks away.
I have now put in 2 small sticky pads at the bottom corners of the plate and its stopped the noise.   ;)
