I took the car out for a spin on Saturday and returning home I stopped for some petrol. Getting back in the car I turned the headlights on and a warning message came up on the dash "Check Number Plate Light". Jumped out had a look and sure enough the NS number plate bulb was out.
Got home and was fannying about in the garage before putting the car away so the car must have been stood for no more than 10mins. Got back in the car, the headlights were already ON from coming home... waiting to see if the warning message came up, nothing. Got back out check the bulb and it is now working. Must be a loose/dirty connection.
Later on I had to go out and pick up SWMBO on with the lights and no warning for about 10mins and then up it popped bulb out. About 3mins after that the dash backlighting then went out. A min or two later on it popped again.
This occured a number of times on the return journey.
Returned home and now with a bit of time on my hands got the bulb out to look and see if the connectors were clean and good fit, which they were. At this time the bulb was not working, and no visible break in the bulb element.
To check and make sure the bulb was at fault, I swaped the number plate bulbs around - the working bulb in the non working posistion. Sure enough this confirmed that the bulb was at fault as the faulty bulb (now in the OS location) did not work.
I've got in the car this morning and the offending bulb still in its reversed location is working again!
I'm going to pick up a new bulb later on, but what worries me more is that its knocking out the dash backlighting (the Dimmer setting is on Max). The two are clearly connected as I've not noticed the backlight dissapearing before the bulb has played up
I take it this isnt usual behaviour?!
