Adrian Flux
Author Topic: Starting delay after turning key (500C)  (Read 474 times)
pvr
« on: January 30, 2011, 05:04:39 PM »
Noticed today that it took about 5 seconds of holding the key before the starter motor kicked in. I had previously seen 1 - 2 seconds, but today seemed very long.
Is this the immobiliser playing up?
BMW Z4M, X5, Golf Clipper, Abarth 500C and a runaround Polo ...
John501
Re: Starting delay after turning key (500C)
« Reply #1 on: January 30, 2011, 05:27:37 PM »
I think thats just a characteristic of the C. It seems to vary quite a bit.
Try pressing the brake a little harder before you turn the key :wave:
Exoticaholic
« Reply #2 on: January 30, 2011, 05:28:32 PM »
Yes, I had the same trouble on my A500c. It was noticeably slower to fire up than my previous Fiat 500.
To be honest, I have no idea whether it is the immobiliser.
CREPITUS WHOOSH!
Trooper
  • Funk White Supremacy
« Reply #3 on: January 30, 2011, 05:30:04 PM »
Had the same problem with my 159 and Spider as they were both push button start you had to have either the clutch or brake pedal pressed and if you were not pressing quite hard they would struggle to start  :'(
Hope this helps  :thumb:
Exoticaholic
« Reply #4 on: January 30, 2011, 05:34:55 PM »
I'm sure I pressed the brake pedal hard before I turned the key. I'll revisit this procedure tomorrow morning.
CREPITUS WHOOSH!
pvr
« Reply #5 on: January 31, 2011, 10:39:06 AM »
I think I press the brake with the same force each time (roughly), but will experiment with force etc.
Must also check if it always ends up in N mode after starting as I could not swear to it that it normally does that.
John501
« Reply #6 on: January 31, 2011, 10:58:41 AM »
You should leave it in gear when you turn it off but it will always select nuetral when you turn the key.
pvr
« Reply #7 on: January 31, 2011, 12:16:53 PM »
Yes, it is always left in gear when turning it off. Think you mentioned it beeps at you if you don't, but have never tried switching it off in N.
ctsui35
« Reply #8 on: January 31, 2011, 02:42:59 PM »
My 500c has not played up yet, touch wood .
Brembo brake kit now on and loving it!
