Had a thought today, a fair few repeat topics occasionally pop up asking if "this is normal" or "is it suppose to do that?" so i was thinking about making a topic for those new owners who maybe don't know about all the features of the A500! It took me a while to learn (and find) them all! I'll start, feel free to add those I've forgotten about!
1. Follow me home headlights, remove key from ignition, flash headlight stalk as many times as you want (increases in 30 second intervals up to 210 seconds) and they stay on for that amount of time, even when car is locked
2. Alternatively, there are the parking lights, remove key from ignition and turn the lights on, both front (DRL's) and rear tail lights (including number plate lights) stay on until you turn them off again. Unfortunately you cannot turn just one direction on like on the Panda, it's all or nothing!Don't let your battery run flat though!
3. Auto dimming dash - when the headlights are turned on, the dash lights up too as normal, but if it's not quite dark enough, or the fading sun is directly on the display, the dash illumination goes off and back on as it pleases depending on light conditions.
4. Glove box, yes there is one, awkward bugger to open though! You'll find it!
5. Heated mirrors, if you have the climate control and you press the "de-mist" button, the side view mirrors also heat up to defrost/demist the side mirrors too! Not many people realise this!
6.Hill holder - When on an upward slope, press the brake pedal, when ready to move off, release the brake pedal and the hill holder will hold the car there from about 2 seconds so you don't need to use the handbrake for hill starts!
7. Lane change indicators - lightly push the indicator stalk up or down depending on which direction you want to go, the indicators will flash 3 times, saves the embarrassment of leaving one on if you're on th motorway with the radio full blast!
8. Dimmer - If the dash display back light is a little too harsh at night, go into the menu and reduce it's brightness. There are several things you can do in the menu actually, including turning the passenger airbag off, and turning the DRL's on/off. Worth a look.
That's all i can think off from the top of my head. Any more?
