Adrian FluxAdrian Flux, proud supporters of Abarthisti
Pages: [1] 2 3
Author Topic: TTC - What exactly is it  (Read 2819 times)
903cc
Esseesse Member
« on: February 25, 2009, 10:14:44 AM »
ReplyReply
Hi All.
The information on TTC in the manual is vague to say the least. What is it exactly? I understand it as an electronic Limited Slip Differential arrangement? If it is then I do not get why it is not turned on all the time. Why is this so?
Admin: edited TTS for TTC  Thumb Up
« Last Edit: February 25, 2009, 10:40:33 AM by AlexK » Logged
Campovolo Grey 500 Esse Esse with Red Leather and Red Stripes, checks and scorpion. Automatic Aircon
Chris555
Administrator
S2000 Member
« Reply #1 on: February 25, 2009, 10:21:40 AM »
ReplyReply
Its a function of the latest bosch braking system that reduces wheel spin in corners by braking rather than by cutting engine power which normal stability controls do. It is consider by Abath to be part of the 'Sports' system so this is why it is not on all the time like the sports button. Although I think they seperated it out from that so you can still engage it in normal mode.
Last sentance is guess work maybe one of the dealers has an official explanation.
Logged
Joe
S2000 Member
S2000 Member
Abarth 500 SuperSport
« Reply #2 on: February 25, 2009, 10:21:52 AM »
ReplyReply
It's TTC - torque transfer control, and unlike other systems it brakes the wheel that starts to spin as opposed to cutting power. It gives the driver the opportunity to cut the wheelspin themselves and execute a corner without any electronic help when it's turned off...
Logged
ORANGE & LIMETrack Days
in association with...
CHICKEN & MEAT r a c i n g
Joe
S2000 Member
S2000 Member
« Reply #3 on: February 25, 2009, 10:22:19 AM »
ReplyReply
damn you beat me to it olopboy!  Angry
Logged
Chris555
Administrator
S2000 Member
« Reply #4 on: February 25, 2009, 10:23:46 AM »
ReplyReply
Ninja posting powers  Grin
Logged
Joe
S2000 Member
S2000 Member
« Reply #5 on: February 25, 2009, 10:29:08 AM »
ReplyReply
I say without any electronic help but the traction control and esp are always engaged. only the electronic diff can be turned off.  Thumb Up
Logged
Chris555
Administrator
S2000 Member
« Reply #6 on: February 25, 2009, 10:33:46 AM »
ReplyReply
And you would be spot on! The esp will just do the engine power sapping trick.
It is worth noting that on the journo day they set up a figure of 8 track to show the TTS off and apparently it works, works very well.
Logged
Joe
S2000 Member
S2000 Member
« Reply #7 on: February 25, 2009, 10:35:28 AM »
ReplyReply
Yeah I heard that, apparently without it engaged it tends to understeer dramaticaally  Undecided
Logged
903cc
Esseesse Member
« Reply #8 on: February 25, 2009, 11:55:34 AM »
ReplyReply
Ok Still not clear. Is it braking the wheel using the Brakes or by some differential trickery?
Logged
Chris555
Administrator
S2000 Member
« Reply #9 on: February 25, 2009, 11:57:40 AM »
ReplyReply
Braking with brakes so the engine is still at power, opposed to cutting power from the engine which esp does. Means you regain control but retain speed engine power for exiting the corner.
Logged
richbrowne
S2000 Member
« Reply #10 on: February 25, 2009, 12:02:34 PM »
ReplyReply
Braking with brakes so the engine is still at power, opposed to cutting power from the engine which esp does. Means you regain control but retain speed for exiting.
Gees you are quick with your responses! I was just about to send a similar reply. Must be some sort of black magic trickery going on! Shocked
Logged
Funk White 500 Abarth esseesse|PaintShield|Red Leather|Red Mirror Backs|Climate|SkyDome|Electrochromatic Rear View Mirror|Aluminium Gear Knob|Assetto Corse Side Stripes by PaintShield On The Way!
903cc
Esseesse Member
« Reply #11 on: February 25, 2009, 05:29:32 PM »
ReplyReply
Thanks for clearing that up  Thumb Up
Logged
richbrowne
S2000 Member
« Reply #12 on: March 05, 2009, 04:57:05 PM »
ReplyReply
The TTC needing to be switched on each time is a pain. Does anyone know why the systen was configured this way?
Logged
Alex_gregory_uk
Assetto Corse Member
Used to own an Abarth 500!!!!
« Reply #13 on: March 05, 2009, 05:01:33 PM »
ReplyReply
This is a complete guess but I'll give it a go!!!!
I would imgaine the computers work overtime working out if a wheel is slipping etc when TTC is switched on so for your average journey it's not required. You do need to be giving the car some to make use of the TTC so quickly pressing the button isn't to much hassle.
Logged
My Launch Edition 500 thread, MTEC low and high beam bulbs, PIAA DRL bulbs, silvervision rear indicator bulbs
richbrowne
S2000 Member
« Reply #14 on: March 05, 2009, 05:16:19 PM »
ReplyReply
Thanks Alex Thumb Up
Logged
Pages: [1] 2 3
Jump to:
Copyright & Credits
Powered by SMF 1.1.16
