Author Topic: Wiper blades?  (Read 5411 times)
Offline Matt2010
Wiper blades?
« on: March 29, 2011, 01:23:53 PM »
I'm after some Bosch Aerotwin wiper blades for front and rear of car but i'm struggling finding the correct fronts.
It seems you need to use 'retrofit' ones as the straight replacement blades will not fit and theres a warning on eBay saying:
"These are standard replacement windscreen wipers only for models fitted with Aerotwin wipers from new (factory fitted).
If your model does not have factory fitted flat windscreen wipers then please do not purchase this type of wiper as they won't fit!"
Does anyone have a link to set of Bosch Aerotwin fronts that are retrofit?
TMC tuning box. GTT cold ram induction kit.
    Offline 3k5k
    • Exactly how long is it.
      • Doncaster
    Re: Wiper blades?
    « Reply #1 on: March 29, 2011, 01:42:30 PM »
    Have you looked at the PIAA Silicone blades. see link.
    http://www.piaa.co.uk/wipers/wipers.asp
    50 Shades of Campovola
    Offline Matt2010
    Re: Wiper blades?
    « Reply #2 on: March 29, 2011, 02:13:21 PM »
    Look good but fiat 500 not listed  :(
    Jarmin Von Nitely
    Re: Wiper blades?
    « Reply #3 on: March 29, 2011, 02:52:03 PM »
    I bought some off eBay for the wifes f500 perfect fit and no more juddering  :thumb:
    Offline Matt2010
    Re: Wiper blades?
    « Reply #4 on: March 29, 2011, 03:08:06 PM »
    The Bosch Aerotwins with code A300S?
    Did your wipers have a little black square you pushed and the blades slid out?
    Offline 3k5k
      • Doncaster
    Re: Wiper blades?
    « Reply #5 on: March 29, 2011, 03:24:39 PM »
    Ring PIAA UK they are quite helpfull.
    kEVO
    Offline simer
    Re: Wiper blades?
    « Reply #6 on: March 29, 2011, 04:22:01 PM »
    Those were the ones I got and they fitted perfectly. Very smooth wipe too. Look for another thread on this and I think you might find the link to where I got them from.
    Offline Matt2010
    Re: Wiper blades?
    « Reply #7 on: March 29, 2011, 04:58:02 PM »
    Yeah searched earlier and found your thread with the ebay link which made me start this post :thumb:
    It said they were for Fiat 500 but at the same time also said "These are standard replacement windscreen wipers only for models fitted with Aerotwin wipers from new (factory fitted)" and not to order if not.
    I took a wiper off today and its Fiat branded which is where the confusion lies if they'll fit or not?! Mines a 59 plate so i'm guessing it wont be a straight swap.
    I've also checked out other online stores and most just show the rear wiper only for the Bosch with many showing as none available.
    So confusing  ???
    Offline simer
    Re: Wiper blades?
    « Reply #8 on: March 29, 2011, 05:42:47 PM »
    Mine is a 58 plate and it was a straight swap.
    Offline Matt2010
    Re: Wiper blades?
    « Reply #9 on: March 29, 2011, 05:50:44 PM »
    Many thanks, will take a punt then :)
    Jarmin Von Nitely
    Re: Wiper blades?
    « Reply #10 on: March 29, 2011, 08:26:29 PM »
    Yes thats them fitted perfectly
    Offline jason.s
    Re: Wiper blades?
    « Reply #11 on: March 29, 2011, 09:40:56 PM »
    FYI, Mine is an 11 plate and the Aeroblades came fitted as standard.
    I cant see any numbers on the blades, although the arms have Fiat on them.
    Offline simer
    Re: Wiper blades?
    « Reply #12 on: March 30, 2011, 08:51:11 AM »
    My impression is that the factory fit blades are to Aerotwin design but with inferior grade, unbranded rubber?
    Offline thefamoushoops
    Re: Wiper blades?
    « Reply #13 on: March 30, 2011, 08:52:38 AM »
    They're certainly not very good.
    Think I'll invest in a set of the Bosch ones as well.
    Offline Trigzzzzzzzzzzz
    • A500 Launch Edition
    Re: Wiper blades?
    « Reply #14 on: March 30, 2011, 04:33:00 PM »
    gunna get myself some of these :-)
