Hi Everyone,
With any luck I will have an APE within the next 2 weeks. Bought it purely with the intention to tune so I have a few questions as info seems to be thin on the ground.
In the old AGP SS they swapped the turbo, does anyone know if the APE already has the uprated turbo and if not what the bhp limit is on the OE turbo?
I realise that the multi-air engine is very different from the old T-Jet so most parts will need to be redeveloped for the APE (can be an advantage, getting discounts as a dev car ect). Does anyone know if the APE runs the same suspension as the AGP? Looking to get some coilovers however springs will do for a short while, any suggestions would be great?
First step seems to be the TMC box, with this fitted can you still flick between normal and sport mode?
It worries me a bit that you cannot put an APE on a RR, has anyone found a way around this yet?
Does anyone know how far you can take the standard internals?
Realistically I would be looking to do the following:
Remap
IK
BOV
Bigger FMIC (Mist spray seams a good option)
Uprated Actuator
Fuel pump & Injectors
More efficient down pipe and straight through system
Potentially Hybrid turbo if engine internals could take it.
Sorry lastly, what’s the max boost people are running atm?
My ultimate goal would be to have it running in the region of 220-230bhp
