Had the SS kit fitting done but found a bit of vibration at speed, gave Vospers a call and sounds like it's balancing needs tweaking, not a problem I thought I'll just pop down the road, my local tyre place is a bit nervous about Jacking it though due to skirts and the fact that the lift they use not have small enough platforms to get in the holes left in theplastic.
Manual doesn't imply anything special is needed, I guess they are being a bit cautious, does anything special need done, or just a case of only being able to jack on exposed frames?
