Adrian Flux
Author Topic: Media player question  (Read 641 times)
ecosse500
« on: September 09, 2010, 10:43:04 PM »
My media player on my a500 is doing my head in! No matter what I do it keeps playing the same song unless I manually change it. I have tried selecting random/shuffle. Taken the stick out etc but still with no luck!
Any help would be appreciated!
Jamie
A500 - BN white - Red stripes - 17" ten spokes - Climate - ETA March/April 2010
Re: Media player question
« Reply #1 on: September 09, 2010, 10:46:24 PM »
take the stick inside and add or delete a song. usually works but if not disconnect the battery for a few seconds.  :thumb:
Paula
  • Some days it all gets a bit too much. . .
« Reply #2 on: September 10, 2010, 09:07:36 PM »
I had this problem initially with my iPhone and found that it was set to repeat song, so have a look at the manual for your media player and see if there's a setting for this that you can change.
Paula
Red A500, 17" 10 Spoke Alloys and Black Leather: It's very red and it goes vroooooom.
bex698
« Reply #3 on: September 10, 2010, 09:49:37 PM »
mine was the same i just told it shuffle off and that worked fine on mine
Trooper
  • Funk White Supremacy
« Reply #4 on: September 12, 2010, 06:35:00 PM »
Or try the voice command "loop off"  :thumb:
TallPaul
« Reply #5 on: October 20, 2010, 09:58:10 AM »
Or try other commands ending in OFF, the system does not recognise them, but it does make you feel better  :whistle:
500 Abarth in white with 10 spokes.
NOW WITH MONZA :D
Lisa1626
« Reply #6 on: October 20, 2010, 12:41:57 PM »
I had the same problem and it turned out that it was on loop on. Like the other guys if you tell it loop off it should be ok  :thumb:
ecosse500
« Reply #7 on: October 25, 2010, 10:17:42 PM »
Thanks folks all sorted. It was on loop! Doh!
Jamie
