Adrian Flux
Author Topic: My Blue & me Ipod adaptor  (Read 2552 times)
aphilpot
« on: April 18, 2010, 09:36:24 PM »
I brought my adaptor last week and for the 1st couple of days the buttons on my steering wheel stopped working (whether or not that was to do with the adaptor I don't know). Then all the buttons started working again and for 2-3 days I had no problems but then today it says no media found. I have tried disconnecting it then reconnecting it, turning the ipod off then back on, switching the car off and on and even trying a different ipod but nothing is working  :thumb:
Does anyone know what could be causing this and how to solve it  ???
Merlot
  • Death To Humans
Re: My Blue & me Ipod adaptor
« Reply #1 on: April 19, 2010, 07:31:09 PM »
You could try putting some MPeg Audio tracks (not ipod AAC) on a USB memory stick and try this instead. If this works ok it could be the adaptor that's the problem. If not it could be a problem with the Blue & Me or maybe the socket. Also I believe the ipod adaptor requires version 5.4 blue and me to work properly. Not sure however how you check what youv'e got. A phone call to your nearest dealer may help or a visit if he's not to far away.
Stealth Black A500, no decals, 10 spoke
BTB Bypass Exhaust
Bilstein Suspension
Chris555
« Reply #2 on: April 19, 2010, 10:38:42 PM »
Could need a full 'reboot' of the B&M happens from time to time, try Merlot's suggestion first as it resets the internal library file that can get corrupted at times (4-5 mp3s on a stick doest the job). If not, wait until the ignition has been off for 5 minutes, pop the bonnet and disconnect the -ve battery terminal (easy with the quick release mechanism) for about 15-20 minutes, reconnect, worth noting you will lose all trip data and need to reset the clock.
Code of Conduct | AUP
Sawbomartin
« Reply #3 on: April 20, 2010, 09:29:40 AM »
Quick question:
The "internal library file" (so when the system says "building media library" etc), is this in effect a track listing that downloads onto the car's B&M hard drive?
Seems an odd set-up.
A500 + TMC + BMC + Ferodo DS2500 + Motul RBF600 + KW V1 + OMP & Strut Braces - rear seats = esseesse+, + Change.
A lap or two at Cadwell, April 2011:
http://www.youtube.com/watch?v=uSgaCrha8Fc
Chris555
« Reply #4 on: April 20, 2010, 10:01:17 AM »
Pretty much, it allows it to do things like random play and remember where it was so you can skip backwards and forwards even if it was in random mode.
