Glyn Hopkin Abarth
Author Topic: Retro fit AUX socket to older Blue&Me  (Read 1028 times)
Luke_A_P
« on: January 03, 2012, 01:28:28 PM »
Has anyone found a way to retro fit an AUX socket to the A500's with the older Blue&Me setup?
Thanks,
Luke
NinjaUK
Re: Retro fit AUX socket to older Blue&Me
« Reply #1 on: January 03, 2012, 01:33:42 PM »
Welcome  :wave:
I don't know of anyone that has done it but you never know someone might spring up and say they have.  :thumb:
GTMartin
  • 500 Board Moderator
« Reply #2 on: January 03, 2012, 01:51:47 PM »
Hi Luke,
I think those that wanted an Aux socket ended up changing the head unit.
By the way, welcome :wave:
Luke_A_P
« Reply #3 on: January 03, 2012, 02:57:31 PM »
Thanks for the welcome, I recently put a deposit down on an 09/09 A500, I collect it on Friday.
It never occurred to me that a car less than 5 years old would not have an AUX in socket.  ???
As I understand it the Blue&Me system connects to the head unit using a standard iso connector. So all you need to do should be get to that line level cable and piggy back a line in socket to it.
Tackling it from the head unit end, you could run a cable from the stereo down the back of the fascia and out of the ashtray perhaps. Does anyone know how you might remove enough of the fascia to run the cable?
Alternatively, does anyone know where the Blue&Me decoder hardware sits? It might be easier to run a cable from there.
In case you are wondering why I am not happy to use the Blue&Me interface, I listen to audio books on my ipod a lot. The ipod has a “skip back 30s” button which is invaluable for audio books. I don’t think that function will be operable if connected through Blue&Me.
Luke
will-w
« Reply #4 on: January 03, 2012, 03:07:01 PM »
It is possible; someone on another forum I frequent (Torque Italia) did it a while ago on a Grande Punto.
Should be the same process with a 500 :)
EDIT:  Just checked and it's actually for adding one to a non-B&M car.  It does however show you which connector it is so you're half way!!
« Last Edit: January 03, 2012, 03:12:40 PM by will-w »
TMC
Luke_A_P
« Reply #5 on: January 03, 2012, 03:15:35 PM »
I think this will give me access to the pins I need without cutting wire:
fitcaraudio.co.uk / fiat-500-bravo-doblo-ducato-parrot-sot-interface-lead-cellular-mute-lead-for-parrot-kits-p-1934
Now I just need somewhere to run the cable to!
Luke
J_a_m_e_s
« Reply #6 on: January 03, 2012, 07:36:45 PM »
Somebody had a faulty standard USB only B&M, when they had it replaced by dealer they replaced it with the new AUX/USB input, should be easily done.
South Wales Member
Luke_A_P
« Reply #7 on: January 03, 2012, 07:51:17 PM »
Ahh, that is very encouraging news. Any idea which dealer? I might give them a call, it would be nice to talk to someone who's actually done the work.
Luke
Sawbomartin
« Reply #8 on: January 05, 2012, 09:27:34 AM »
Please keep this thread going to conclusion. I'm looking to do the same so very interested.
A500 + TMC + BMC + Ferodo DS2500 + Motul RBF600 + KW V1 + OMP & Strut Braces - rear seats = esseesse+, + Change.
A lap or two at Cadwell, April 2011:
http://www.youtube.com/watch?v=uSgaCrha8Fc
Luke_A_P
« Reply #9 on: January 05, 2012, 10:45:27 AM »
I will of course report on how things go. I have two lines of attack at the moment:
The first it to ask a fiat garage if the can replace the system with the newer one. I have spoken to a garage but they can’t give a cost until I have the chassis number when I pick up the car tomorrow. (Where is the chassis number found by the way?) This option may be prohibitively expensive because it may require a new fiat head unit which won’t be cheap.
The second option is to piggy back on the existing system. From what I have learnt Blue&Me uses an analog input to the head unit and controls when that input is turned on using the digital interface. I will try connecting a 3.5mm jack to the same input in parallel to the Blue&Me input. Keeping the AUX active will require looping a silent mp3 on a usb stick, but that shouldn’t be too arduous. The Bluetooth hands free will still work but it won’t mute the aux input automatically. The only bit I am nervous about is being able to find a way to route the new aux cable from the back of the head unit to somewhere convenient without having to disassemble the whole dash.
It'll be a couple of weeks before I look at it because stupid old me arranged to pick up a new car 2 days before I go skiing! :-\
will-w
« Reply #10 on: January 05, 2012, 12:16:40 PM »
Plan B sounds more achievable (and considerably cheaper!) and has been done before..
As for location, would the glove box not do the trick?
TMC
Luke_A_P
« Reply #11 on: January 05, 2012, 12:34:32 PM »
The glove box would be great. IMO a flying lead in the glove box is more convienient than a socket on the floor next to the hand brake. The thing is I wonder how much of a pain in the a**e it will be to run the cable into the glove box. I would like to avoid disassembly and cutting holes in the plastic.
NinjaUK
« Reply #12 on: January 05, 2012, 12:39:03 PM »
Use the holes that are there for the fusebox.
will-w
« Reply #13 on: January 05, 2012, 06:18:18 PM »
:thumb:
Don't know if the a500 is the same but there are loads of holes through that way in the AGP :)
TMC
J_a_m_e_s
« Reply #14 on: January 05, 2012, 07:04:41 PM »
I did have a look for the other member that had it changed but no luck sorry
South Wales Member
