Glyn Hopkin Abarth
Author Topic: fitting pressed plates  (Read 548 times)
tez-abarth
« on: November 20, 2011, 04:58:18 PM »
I got some legal pressed plates for my 500 abarth and i have used foam sticky pads for the rear plate but at the front I'm struggling to fit the plate with the pads as it does not sit right on the small curve
 . I am now thinking about drilling the plates and screwing them on is that a good idea ? cheers  :thumb:
J_a_m_e_s
Re: fitting pressed plates
« Reply #1 on: November 20, 2011, 05:12:02 PM »
If the plate is metal cant you slightly bend it?
South Wales Member
Exoticaholic
« Reply #2 on: November 20, 2011, 05:13:26 PM »
If the colour of the screws match the area where the holes are, then it will be ok. You wouldn't want the front plate to fall off in mid motion were it affixed on pads would you?
Can you tell me where you sourced them please? I would like some for myself.
CREPITUS WHOOSH!
GTMartin
  • 500 Board Moderator
« Reply #3 on: November 20, 2011, 05:15:20 PM »
We've stuck our front plates on with 4 sticky pads. You could try using a few more and making sure all surfaces are really clean and grease free.
tez-abarth
« Reply #4 on: November 20, 2011, 05:22:18 PM »
i got them from a shop in leeds mate but you can buy them online
go on this website and enter your post code and find a dealer near you but if there isn't a dealer near you just get them of this website aswell   :thumb:
3k5k
  • KEV & BEVS TWIN SCORPIONS
« Reply #5 on: November 20, 2011, 06:10:12 PM »
I bought some two sided adhesive tape from Ebay, its around 4mm to 5mm thick around 40mm wide
Stick two lengths of tape the full length of the number plate.
You only get one go at sticking it on, so you need a good eye for it been level, remove the backing tape and press it on. Once on it stays on.
The front plate can be bent slightly to accommodate the curve of the front bumper.
WHOOSH BANG!
olig
  • CHICKEN AND MEAT Racing
« Reply #6 on: November 20, 2011, 06:46:28 PM »
I drilled and screwed my pressed plates..
CHICKEN & MEAT racing
Joe
« Reply #7 on: November 20, 2011, 09:08:44 PM »
I bent mine and stuck it in like KEVO  :thumb:
24 Heures du Mans 2012... 23 days to go!
Potter77
  • Hopefully Fast
« Reply #8 on: November 20, 2011, 09:11:20 PM »
Get you get pressed plate's in the west country with my carrot's or do I need to go online?
Potter77 :)
BN White Red Leather Climate Anti Dazzle Rear Mirror 50/50 Rear Seat Black Assetto Corse Stripes Black OZ Leggenda's Big Turbo TMC 230 Massive Brembo Brakes Hel Brake Lines Racing Brake Fluid Novitec exhaust Bilstein Coilovers Quate LSD Induction Kit Silicone Hose and just a few more bits to go:)
olig
« Reply #9 on: November 20, 2011, 09:12:32 PM »
Potter77 :)
I got them online.. there is a place in bridgwater that do them tho.
Potter77
  • Hopefully Fast
« Reply #10 on: November 20, 2011, 09:15:42 PM »
Potter77 :)
Thanks Oli
Potter77 :)
cbslade
« Reply #11 on: November 22, 2011, 03:50:40 PM »
Click here for Dubmeister in Bridgewater who make UK legal pressed metal plates. We've got them on our Abarths and just stuck them on with sticky pads - there weren't any problems or issues fitting them...  ???
CB51 ADE: Black F500 1.4 Sport
CB52 ADE: White A500
CB53 ADE: Grey A500, TMC box
CS11 ADE: Black A500, GTT Level 2, ASV and induction.
SS11 ADE: White BMW X5. The wife's....
Potter77
  • Hopefully Fast
« Reply #12 on: November 23, 2011, 09:56:01 PM »
Thank you
Potter77 :)
smilesoffun
« Reply #13 on: November 24, 2011, 09:31:01 PM »
 Had the same issue so just took the plate off  :whistle:
 Simple as pees  :thumb:
Don't Fear Speed Ride It
2011 Grey 500 Abarth
1972 Yellow 500 Abarth
1966 Red 1000 tc Abarth
cbslade
« Reply #14 on: November 25, 2011, 09:10:45 AM »
We've got four (1 Fiat and 3 Abarth's) all of which have had pressed plates on their entire lives without any issues. The biggest problem I have on mine is that people keep reversing into me when parked and so the plate isn't quite the same shape as when I put it on...  :o
« Last Edit: November 25, 2011, 09:12:44 AM by Chris555 »
