Lipscomb Abarth
Author Topic: Servicing Info for all Abarth models  (Read 4045 times)
« on: March 02, 2011, 02:00:37 PM »
This sticky details the official servicing requirements for all Abarth models - Grande Punto, Evo, 500, 500C and 695, including all esseesse models.
This information comes direct from Abarth and supersedes any information contained within vehicle handbooks.  It is the same information that is published on the electronic system (eLearn) used by Abarth to inform the dealer network and is therefore the same information as available to your local dealer.  The information has been checked thoroughly, and any changes from the handbook have been confirmed by Fiat Technical as being correct.
Therefore, to the best of our knowledge, the information contained here should be regarded as correct wherever a contradiction appears with your vehicle handbook.
Servicing Summary
Model Oil Changes Services
Abarth Grande Punto 18k miles/24 mnths* 18k miles
Abarth Grande Punto SS 6k miles/12 mnths 18k miles
Abarth 500 9k miles/12 mnths 18k miles
Abarth 500C 9k miles/12 mnths 18k miles
Abarth 500 SS 6k miles/12 mnths 18k miles
Abarth 500C SS 6k miles/12 mnths 18k miles
Abarth 695 Tributo Ferrari 6k miles/12 mnths 18k miles
Abarth Punto Evo 9k miles/12 mnths 18k miles
Abarth Punto Evo SS 6k miles/12 mnths 18k miles
* low mileage clauses apply
Further information
Specific information for each model can be found by following these links:-
Abarth Grande Punto
Abarth 500
Abarth 500C
Abarth 500 SS
Abarth 500C SS
Abarth Punto Evo
Abarth Punto Evo SS
« Last Edit: April 07, 2012, 09:03:23 AM by AlexK »
Abarth Grande Punto (non-esseesse)
« Reply #1 on: March 02, 2011, 02:01:10 PM »
Miles (x 1,000) 18 36 54 72 90 108
Check tyre condition/wear and adjust pressure if necessary
Check operation of lighting system (headlamps, direction indicators, hazard warning lights, passenger compartment, luggage compartment, instrument panel warning lights, etc.)
Check operation of screen wash/wipe system
Check front and rear disc brake pad condition and wear
Visually inspect condition of exterior bodywork, underbody protection, rigid and flexible pipes (exhaust, fuel system, braking system), rubber elements (boots, hoses, bushes, etc.)
Check cleanliness of bonnet and boot locks, cleanliness and lubrication of linkage
Visually inspect condition of various drive belts
Replace auxiliary drivebelt(s)
Check handbrake lever travel and adjust if necessary
Check exhaust gas emissions
Check evaporation control system
Replace air filter cartridge
Top up fluid levels (engine coolant, brake fluid, battery, screen washer, etc.)
Replace spark plugs (+)
Check condition of toothed timing drive belt
Check operation of engine management systems (using diagnostic socket)
Replace toothed timing drive belt (*)
Change engine oil and replace oil filter (or every 24 months) (**)
Change brake fluid (or every 24 months)
Change pollen filter (or every 24 months)
(*) Irrespective of the mileage, the timing belt must be changed every 5 years or every 4 years for heavy-duty use (cold climates, town use, long periods of idling, dusty areas).
(**) If the vehicle is used mainly around town or the annual mileage is less than 6,000 miles, the engine oil and engine oil filter must be changed every 12 months.
(+) Only use spark plugs specifically certified for T-Jet engines.
Summary
The vehicle must be serviced every 18,000 miles.
However, if the mileage travelled in the last 12 months was less than 6,000 miles, an engine oil and filter change must be carried out.
If the mileage travelled in each year is more than 6,000 miles but not enough to reach 18,000 miles in 24 months, an engine oil and filter change must be carried out after 24 months.
See separate guide for esseesse versions.
Abarth Grande Punto esseesse
« Reply #2 on: March 02, 2011, 02:01:43 PM »
Miles (x 1,000) 6 12 18 24 30 36 42 48 54 60 66 72 78 84 90 96 102 108
Change engine oil and replace oil filter (or every 12 months) (**)
Summary
An engine oil and filter change must be carried out every 6,000 miles or 12 months, whichever is sooner.
Abarth 500, 500C (non-esseesse)
« Reply #3 on: March 02, 2011, 02:02:07 PM »
Miles (x 1,000) 9 18 27 36 45 54 63 72 81 90 99 108
Check windscreen wiper/washer operation, adjust nozzles
Check windscreen/rear window blade position/wear
Check condition/wear of front disc brake pads and operation of pad wear indicator
Check soft top operation while opening/closing, control of seals and lubrication of top fabrics sliding side guides (or every 12 months) (500C only)
Check tension of accessory drive belt(s) and adjust if necessary
Visually inspect condition of accessory drive belt(s)
Replace accessory drive belt(s)
Check condition/wear of rear disc brake pads
Inspect condition of toothed timing drive belt
Check gearbox oil level (not 500C)
Change pollen filter (or every 12 months)
The oil of the Abarth Competizione gearbox of the 500C is of the 'For Life' type and does not require regular checks.
Summary
An engine oil and filter change must be carried out every 9,000 miles or 12 months, whichever is sooner.
See separate guide for esseesse and 695 versions.
Abarth 500 esseesse, 500C esseesse, 695 Tributo Ferrari
« Reply #4 on: March 02, 2011, 02:02:28 PM »
Check gearbox oil level (not 500C or 695)
500/C esseesse and 695 Tributo Ferrari versions require an engine oil and oil filter change every 6,000 miles or every 12 months or after every race.
The oil of Abarth Competizione gearbox of the 500C and 695 versions is of the 'For Life' type and does not require regular checks.
Summary
Abarth Punto Evo (non-esseesse)
« Reply #5 on: March 02, 2011, 02:02:50 PM »
Check windscreen wiper/washer operation, adjust jets if necessary
Check condition/wear of rear disc brake pads and operation of pad wear indicator
Check and top up fluid levels (engine coolant, brake fluid, battery, screen washer, etc.) if necessary
Visually inspect condition of toothed timing belt
Change pollen filter (or every 15 months)
(+) Only use spark plugs specifically certified for MultiAir engines.
Summary
Abarth Punto Evo esseesse
« Reply #6 on: March 02, 2011, 02:03:11 PM »
Summary
Re: Servicing Info for all Abarth models
« Reply #7 on: March 18, 2011, 10:46:25 PM »
Servicing Errata are available for Abarth 500 and Punto Evo.  They further confirm the contents of this thread.
« Reply #8 on: April 07, 2011, 05:19:28 PM »
To clarify a few points:
- There is NO such thing as a low mileage service for any Abarth model.
- FAMP, the system dealers use to produce fixed price menu servicing, IS NOT CORRECT for the Abarth models.  In fact, it's no longer correct for Fiat, either.
- Oil changes and services DO NOT need to be alternated, i.e. if your last trip to the dealer was for an oil change, you do not automatically need a full service next unless you've reached the required mileage (18k).
- Servicing is NOT time-based - it is entirely mileage dependent.  The only exceptions to this are: engine oil and filter, pollen filter, brake fluid and timing belt which must be changed as per the above charts.
Here's an extreme illustration: Imagine an Abarth 500 that does extremely low mileage of only 2,000 miles a year.  It would require the following visits to the dealer:
TimeMileageWork Required
1 Year2,000Change engine oil, oil filter, pollen filter
2 Years4,000Change engine oil, oil filter, pollen filter, brake fluid
3 Years6,000Change engine oil, oil filter, pollen filter
4 Years8,000Change engine oil, oil filter, pollen filter, brake fluid, timing belt*
5 Years10,000Change engine oil, oil filter, pollen filter
6 Years12,000Change engine oil, oil filter, pollen filter, brake fluid
7 Years14,000Change engine oil, oil filter, pollen filter
8 Years16,000Change engine oil, oil filter, pollen filter, brake fluid, timing belt*
9 Years   18,00018,000 Mile Service
* As in this example the car is likely to have been used mainly for town driving, the 'heavy duty use' clause requires the timing belt to be changed every 4 years instead of 5.
