Corkills Abarth
Author Topic: TURBO Problems  (Read 536 times)
dank264
TURBO Problems
« on: January 20, 2012, 07:01:02 PM »
Hi all
Hopfully someone can shed some light on this. When you put ur foot down and hit about 3.5k revs the car seems to jutter through the rest of the revs. feels like it gets stuck for a couple of seconds on 5k revs then goes again.
could be mis firing but not sure.
anyone know what this could be?
Dan
tez-abarth
Re: TURBO Problems
« Reply #1 on: January 20, 2012, 07:34:53 PM »
air leak maybe  :thumbd: back to the dealers
ashley_r_84
Re: TURBO Problems
« Reply #2 on: January 20, 2012, 11:08:12 PM »
Vacuum hose has split on your turbo :thumb:
CHICKEN & MEAT RACING.
dank264
Re: TURBO Problems
« Reply #3 on: January 20, 2012, 11:30:20 PM »
hopefully its not to major. will book it into thames fiat asap. and its only 10 months old.
could also be to much pedal to the metal :-)
Yordan
  • 2012
Re: TURBO Problems
« Reply #4 on: January 20, 2012, 11:58:32 PM »
It isn't major just make sure they've got the part. You might get some warning lights.
biancodiablo
Re: TURBO Problems
« Reply #5 on: January 21, 2012, 07:11:26 AM »
thought i was the only one with this ! ... its annoying. is yours standard or remap/esseesse ? , ive remapped (sanspeed stage 1, 170bhp) , but definitely feels "fluffy" at 3-4k rpm , almost like a flat spot , been told its the turbo "backing off" . getting service soon , so will get all pipes etc checked out for leaks , cant remember this happening prior to remap, but maybe coincidental. will report back once checked out.
dank264
Re: TURBO Problems
« Reply #6 on: January 21, 2012, 08:50:41 AM »
yep lots of flat spots. min is TMC so i took it out and its back to standard with the same problem. hmmm. trip to fiat is needed.
biancodiablo
Re: TURBO Problems
« Reply #7 on: January 30, 2012, 08:36:13 PM »
speak to graham at sanspeed... mine had similar problem, now sorted and remapped !
dank264
Re: TURBO Problems
« Reply #8 on: January 31, 2012, 08:26:16 AM »
got it back from Fiat. they reset the ecu and everything seems to work perfect.
