Corkills Abarth
Author Topic: Stainless brake lines  (Read 335 times)
barwell1992
« on: December 24, 2011, 03:23:38 PM »
any one fitted stainless braided lines to there agp ?
big difference?
my brakes are crud, great inital bite but then not a lot after and fade alot, just got some front pads to put in but was wondering what peoples opinions where
i have some braided lines on my saxo with GTI6 brakes that only just fit under the 14" wheels (like 2mm of clearance ;p) and they made a huge change in the feel but that dosn't have abs so not sure if it would make the same amount of difference
Andrew
  • AGP Board Moderator
Re: Stainless brake lines
« Reply #1 on: December 24, 2011, 03:42:05 PM »
Try changing your brake fluid  :thumb:
TMC-Motorsport
« Reply #2 on: December 24, 2011, 05:07:38 PM »
I have braided lines on mine with race fluid, difference is day and night.
barwell1992
« Reply #3 on: December 24, 2011, 06:45:35 PM »
hmm tempted, is it the same deal as normal with bleeding on an abs system? only done non abs system's
got my self some castroll race fluid that i use'd in my bike dot 3 or 4 cant remember
whats the recommended fluid type ?
matt owens
« Reply #4 on: December 29, 2011, 06:18:29 PM »
I fitted Goodridge stainless hoses to mine, improved the feel of the brakes hugely even when using standard Dot 4 fluid.
Ricey155
  • Abarth 500
« Reply #5 on: December 29, 2011, 07:17:01 PM »
worked wonders on the A500 had them on my race bikes (racing you had to)
i got mine from Hel (brake lines) any colour you want  :thumb: bought the fronts only, think id go for new calipers soon
£35 for fronts only  :thumb:
