Glyn Hopkin Abarth
Author Topic: Chattering/squeaking when idling from cold  (Read 1194 times)
« on: October 27, 2009, 10:49:51 AM »
Hardly a life-threatening issue, but does anyone else's GPA make a chattering/squeaking noise when idling from cold?
It's like a squeak from a pulley bearing, and normally disappears when you blip the throttle.  Can't hear it from inside that much.
Had it on older cars before caused by dry belts, but it's a bit embarrassing on a fairly new car when sitting in traffic.
Anyone else?
Re: Chattering/squeaking when idling from cold
« Reply #1 on: October 27, 2009, 01:38:31 PM »
yep, i,ve got this, i,d describe it as a chirruppy sort of squeek, comes on  at start up and disappears after 2 minutes at the most.
can.t demonstrate it to the garage without leaving car over night so haven,t bothered mentioning it to them
« Reply #2 on: October 30, 2009, 12:10:04 PM »
Yup, that sounds like it.
Cheers, fella.
DraigFlag
« Reply #3 on: October 30, 2009, 06:50:26 PM »
An old car of mine used to do that, do you what i used to do to fix it? (prepare yourself for a laugh) I used to open the bonnet and whilst the engine was running, spray a fine mist of WD-40 towards the fan belt as it went round. After a few gentle sprays, the squeak would stop. But i don't think it's a good idea as it could cause the belt to slip.
libebcnof23
« Reply #4 on: October 30, 2009, 07:17:55 PM »
It might do but as I pull away I wouldn't be able to hear it over all the rattles and squeeks from the interior trim  :whistle:
AGP Black ,red stripe ,titanium alloys ,sky dome roof
richardmajor86
« Reply #5 on: October 31, 2009, 01:54:16 PM »
What i do to couteract this issue, is have the radio on, almost always.  I really cant be bothered to drive the 120 mile round trip to see a man, who tells me there isn't a lot he can do about a rattle in my dash which i cant really pin point. I cant see the abarth tech is going to want to dismantle my whole dash in a hope of finding something vibrating slightly.
A84RTH
« Reply #6 on: October 31, 2009, 02:51:05 PM »
ive taken mine back for every little rattle only rattle got now is the back seat on drivers side wont clip in place properly so it going back on monday. not had the noise you people have yet.
:)Kim & Anthony:)
Hozepipe
« Reply #7 on: October 31, 2009, 03:04:19 PM »
Sounds a little like my loose spark plug problem (I thought it was a pulley or similar) but the whistle started/continued when the throttle was blipped and the engine was warm - so maybe not. Worth checking that they are OK though.
Delany's car launched a loose plug into the engine bay at 1.8 bar. :'(
cb500t
« Reply #8 on: November 02, 2009, 01:58:44 PM »
Wouldn't that be 1.8 bar plus compression figure?  :o
matthew9712
« Reply #9 on: February 01, 2010, 12:39:03 AM »
There is now a modification out for this problem, it consists of a new belt being fitted and a water drain to deflect water from filling your alternator and freezing. Might be in for a wait to have it solved as many dealers will be requesting belts and modification kits.
DraigFlag
« Reply #10 on: February 01, 2010, 05:50:29 PM »
The MiTo i have at the mo with the same 155 HP engine and 6 speed box as the GPA also has an embarrassing chattering squeak too, doesn't seem to go either but can only hear it at low revs at low speed. It also has the screechy brakes too, but I'm not bothered because it's not mine!  :D (possible topic merge? As i double posted in both  :whistle:)
duncs04
« Reply #11 on: February 11, 2010, 12:05:34 PM »
Took this video this morning, after a 30 minute drive to work.
http://www.youtube.com/watch?v=F8iRoYk_rA4
I think that its the belt which is making the noise.
Tom
duncs04
« Reply #12 on: February 11, 2010, 05:12:15 PM »
is this what other people are having problems with?
« Reply #13 on: February 11, 2010, 05:47:45 PM »
That's exactly it.  It's not the timing belt, it's just the auxiliary drive belt, and matthew9712 reports there seems to be a fix for it.
I've merged this with an earlier thread since we seem to have a few on the go about this topic now.
Lewis
« Reply #14 on: February 11, 2010, 06:35:04 PM »
I have noticed that on mine too....
White AGP SS with 'Frau Leather/Alcantara' Sabelt Seats, climate control, stripes and white wheels. - It's here!
