Vospers AbarthVospers Abarth, proud supporters of Abarthisti
Pages: [1]
Author Topic: does anyone know the next step? (brakes again)  (Read 917 times)
stokiedazza
Abarth Wannabe
« on: February 23, 2010, 08:52:44 AM »
ReplyReply
over the pathetic squealing brakes? I can put on with the high pitched quiet one but not the one that sounds like a bloody lorry coming up to a round about. I was taking the misses work this morning and i realised that i had started to brake differently to avaoid the noise which is not only prob dangerous but why the hell should i?!?!?!??!?!? Platts have been fantastic but its now time to put some pressure on Abarth and Fiat. I know other people with Brembo brakes on different cars and theirs are fine. Sort it Abarth...or should i say Fiat  Thumb Down
Grrr
Logged
Brembo
Assetto Member
« Reply #1 on: March 08, 2010, 08:42:28 PM »
ReplyReply
I had the shims fitted on my Punto but they still squeel from time to time!
Logged
jf11
Abarth Wannabe
« Reply #2 on: March 10, 2010, 12:00:58 PM »
ReplyReply
Ditto! Shims fitted a few thousand miles ago seemed to sort out the problem temporarily but now it is imitating a Leyland bus again.  I seem to get a 'two-note' squeak as if both brakes have started squeaking at the same time. I’m wondering whether they put copper grease on the shims and it has now washed off over the winter.  I shall have to ask …
Logged
John
- with thanks to Svein Erling who created the cartoon of the Fiat 127
picasaweb.google.com/.../yvu-408OlK9A0x59a-5u_w
domc
S2000 Member
« Reply #3 on: March 10, 2010, 10:35:11 PM »
ReplyReply
There are new pads too, had them fitted when I got the shims, not heard anything since. That was nearly 12 months ago.
Logged
richardmajor86
S2000 Member
« Reply #4 on: March 11, 2010, 06:54:13 PM »
ReplyReply
11 months, and 18000 miles later, no squeaks at all for me
Logged
azbo87
Assetto Corse Member
« Reply #5 on: March 13, 2010, 11:34:44 AM »
ReplyReply
Had the shims and pads fitted but recently started hearing a different type of squeal it is quieter than before and I've only done 7000 miles on the car but i brake gently most of the time
Logged
stokiedazza
Abarth Wannabe
« Reply #6 on: March 18, 2010, 02:18:22 PM »
ReplyReply
there must be somthing they can do. No way i can put up with the load screach. Ive looked at other cars with Brembo brakes on and they dont seem to do it  Thumb Down
Logged
azbo87
« Reply #7 on: March 19, 2010, 11:32:24 AM »
ReplyReply
I'm sure mine are gradually getting louder again it is when I brake gently it does it when I increase the braking to be slightly heavier it stops
Logged
azbo87
« Reply #8 on: March 19, 2010, 12:20:30 PM »
ReplyReply
Just had a look into squealing brakes and found some bits and there seems to be other cars with brembo's that squeal aswell
Just found some causes into squealing brakes
Squealing brakes indicate one of two things - pad type or poor pad installation.
By pad type I refer to the triangle of inequality - in this case, clean pad/effective pad/quiet pad - and as they say, pick two. You can get a quieter pad, but you'll have to give up cleanliness or stopping power.
Generally pads that have better performance and dust characteristics squeal while cold - when they warm up the squeal is gone.
The other possibility, poor installation, means that an even backing compound is not in place. By removing the pads, cleaning the backing plate, reapplying a smooth and even backing you may lose this.
Also found out in some cases of squealing brakes just change the pad to another manufacture's pad has cured this
But then it could also be the caliper design and this is a reason why new car dealers just dismiss the problem and as alot of us have had the pads changed and shims put on this is why they may not be doing anymore
Logged
neilbrunton
Abarth Wannabe
« Reply #9 on: March 19, 2010, 01:03:49 PM »
ReplyReply
My daughters AGP brakes have just started squealing so when I was at the dealer last week having my service at Westover Sports Cars I spoke to the salesman about it. He said it was caused because the brake are high performance pads and are made of a harder material than normal brakes so do need to be heated up more to work properly. So a regular thrash and heavy breaking session should sort the problem out. He also said that the problem is more apparent in the winter/spring when it is cold and damp.
So drive faster and brake harder.
Logged
Standard 500 Abarth Remapped to 173hp and 197 lb.ft
jf11
Abarth Wannabe
« Reply #10 on: March 19, 2010, 02:46:46 PM »
ReplyReply
Quote "But then it could also be the caliper design and this is a reason why new car dealers just dismiss the problem and as alot of us have had the pads changed and shims put on ... "
Thanks!  Been in to SG Petch today. As usual, friendly staff, but all they seem to be able to think of doing is replace the pads and shim kit (again). Humm... another letter to FIAT I suspect - I should learn, ever since my 127 Sport I have been having problems with them. The file is getting bigger.
Anyone want a 9K miles GPA (with new brake pads)?   Wink
Logged
John
JamesGPA
Assetto Member
« Reply #11 on: March 22, 2010, 03:47:44 PM »
ReplyReply
You could try changing the pads to another type, I thought the esseesse's pads were a harder compound?
I had the shims fitted and I have to clean the brakes out and re-grease every six months otherwise the high pitch squeel returns, I expected them to squeel again after winter though tbh.
You can try driving/braking harder but that only works in the very short term, as in as soon as the next time you want to stop. Smiley
Logged
AGP, Black, climate, leather, stripe, upgraded bulbs
Pages: [1]
Jump to:
Copyright & Credits
Powered by SMF 1.1.16
