Meridien Milano
Author Topic: First little niggle  (Read 547 times)
MickL
First little niggle
« on: July 27, 2009, 05:15:19 PM »
After owning my AGP for two weeks , I took wife out for a drive ,and as we past 50mph and with no music on , she commented on wind noise coming from the passenger side door. None was coming from my(the drivers) side and to be honest I could hear the noise coming from her side. On the return journey I let her take the wheel to see if I could locate  the source. I seem to of narrowed it down to just by the very front of the upright on the window.
Has anybody else suffered similar problem or are my wife and I being picky ??
AGP 1949 White , SkyDome Roof, Climate Control Alternative Alloys ,Abarth Dust Caps :-)
John501
Re: First little niggle
« Reply #1 on: July 27, 2009, 05:44:38 PM »
Not really some thing I have come across before Mick but we canhave a look when we do your door handle :thumb:
magicmole
« Reply #2 on: July 27, 2009, 08:34:42 PM »
I have the same problem. It's been checked and I've been told that there is nothing wrong with the way the door has been fitted.
MickL
« Reply #3 on: July 28, 2009, 01:39:25 PM »
If I am told the same , its not really good enough ! >:(
wampa
« Reply #4 on: July 28, 2009, 01:48:23 PM »
It's annoying to have an issue so soon, will you be covering your tatoo if the issue is not solved? (a la Katie and Peter).
Joking aside, I am sure John will get his guys to have a good look at it for you. (The car, not the tattoo) :whistle:
magicmole
« Reply #5 on: July 28, 2009, 04:33:15 PM »
It's not the end of the world as far as I'm concerned. I'd kick up if it was something serious. Besides it's a Fiat, not a Lexus.
Tyre roar from the original tyres was much more of a problem.
DevilAndGod
« Reply #6 on: July 28, 2009, 04:41:14 PM »
Has yours always done it? I didn't notice at Stanford. Then again.. there were other things to be listening to,
Nothing is like an ABARTH
Size, shape, speed and SPIRIT
magicmole
« Reply #7 on: July 28, 2009, 05:47:31 PM »
Yes.
The run you had wouldn't have shown the problem anyway. It was drowned by exhaust/induction roar as you say.
It's noticeable at constant speed.
A84RTH
« Reply #8 on: July 29, 2009, 10:24:12 AM »
Not noticed the wind noise on ours, but then again i was more concerned with the creaking noise we could hear at the rear (not door locks as they had already been checked) & the water filling up in the rear footwell, had it checked out & apparently the bulkhead needed re sealing, so new carpet & underlay after 8 months, great - Not.
Will listen out for the wind tho just incase :)
:)Kim & Anthony:)
MickL
« Reply #9 on: July 29, 2009, 02:10:35 PM »
Rushing out to check rear footwells. Its been raining non stop for nearly 3 days now :(
A84RTH
« Reply #10 on: July 29, 2009, 02:48:26 PM »
thats what made us notice, it had been raining really heavy around 16/17th july, we had been away for 3 days & came back to water. check in that little sliding bit in drivers footwell under mat, if its dry in there you should be fine, ours wasn't :)
:)Kim & Anthony:)
