Glyn Hopkin AbarthGlyn Hopkin Abarth, proud supporters of Abarthisti
Pages: [1]
Author Topic: Abarth Grande Punto and Grande Punto Esseesse Technical Specifications  (Read 2894 times)
Administrator
S2000 Member
« on: October 21, 2008, 10:44:23 AM »
ReplyReply
Engine
    * 4 cylinders in line, 4 valves per cylinder, 1368 cc
    * Power: 155 hp at 5500 rpm
    * Max torque 206 Nm at 3000 rpm (230 Nm at 3000 rpm Sport Boost mode)
    * Drive-by-wire throttle with no mechanical connection
    * Garrett IHI RHF3-P10.5 fixed geometry turbocharger
Transmission
    * 6-speed gearbox
    * Dual cable external gearbox drive
Suspension and steering
    * MacPherson strut front and anti-roll bar
    * Torsion beam suspension at the rear
    * Lowered sports suspension
    * Electric power steering with Sport Boost mode
Brakes
    * Fixed front calliper: Brembo M4×40, four piston
    * Ventilated front brake disc ø 305 mm x 28 mm
    * Rear calliper with piston ø 54 mm
    * Rear brake disc ø 264 mm x 11 mm
Bodywork
    * Deepened front and rear bumpers
Wheels & Tyres
    * Aluminium alloy, 7″ x 17″
    * Tyres: 215/45R17
CO2 emissions
    * 159 g/km
Fuel consumption
    * Urban consumption: 30.1 mpg
    * Extra-urban consumption: 54.3 mpg
    * Combined consumption: 42.2 mpg
Dimensions
    * length 4041 mm
    * width 1721 mm
    * height 1490 mm
Weight
    * 1185 kg
Performance
    * Top speed 129 mph
    * 0-62mph 8.2 secs
NB: Cars ordered after 4/8/2009 with factory option 57X - 'Homologation code' benefit from reduced emissions (down to 159 g/km from 162) and improved economy: 30.1 mpg urban (was 29.4 mpg), 54.3 mpg extra-urban (was 53.3 mpg), 42.2 mpg combined (was 40.9 mpg).
« Last Edit: February 24, 2011, 09:22:40 AM by AlexK » Logged
I'm taking a break: if you need something, please PM a member of the moderator team.
Administrator
S2000 Member
« Reply #1 on: October 21, 2008, 10:44:50 AM »
ReplyReply
Esseesse kit contents
Replacement Garrett GT 1446 turbocharger which increases boost pressure from 1.3 to 1.5 bar, new water and oil pipes to the turbo, new exhaust manifold, heat shield, injector rail, MAP sensor, boost sensor, modified catalytic converter, larger diameter exhaust, new intercooler pipework, adapted radiator pipe, new water pump, wastegate valve, BMC air filter, and new engine ECU.
It also includes the contents of the Assetto kit: four springs that lower the ride height by 15-20mm, high-performance front brake pads, cross-drilled front disc brakes, 18" alloy wheels in white or titanium with 215/40 ZR18 Pirelli P-zero tyres.
Engine
    * Four cylinders in line, 4 valves per cylinder, 1368 cc
    * Output: 180bhp at 5750 rpm
    * Max torque 272 Nm at 2750 rpm
    * Garrett GT 1446 fixed displacement turbocharger
Transmission
    * 6-speed gearbox
    * Dual cable external gearbox control
Brakes
    * Fixed front callipers: Brembo M4×40, dual piston
    * Ventilated front discs ø 305 mm x 28 mm
    * Rear callipers with piston ø 54 mm
    * Rear discs ø 264 mm x 11 mm
Bodywork
    * Deep front and rear bumpers, spoiler, sideskirts
Wheels & Tyres
    * Aluminium alloy, 7″ x 18″
    * Tyres: 215/40 ZR18
Performance
    * Top Speed 133 mph
    * 0-62 mph 7.5 secs
« Last Edit: February 24, 2011, 09:22:10 AM by AlexK » Logged
Gofra
Assetto Corse Member
« Reply #2 on: November 04, 2008, 05:41:43 PM »
ReplyReply
Its probably "old news" to you guys but the real performance figures of acceleration are different:
Auto (italian automotive magazine):
0-100: 7,76s
0-400: 15,7s
Elaborare (italian automotive magazine):
0-100: 7,75s
0-400m: 15,76s
Quattroruote (italian automotive magazine):
0-100: 7,8s
0-400m: 15,8s
I made a test myself and managed around 8.2 - 8.3-ish with wet tires and moist asphalt (and gear change far from optimal).
Greetz,
Frane
Logged
Pages: [1]
Jump to:
Copyright & Credits
Powered by SMF 1.1.16
