Wessex GaragesWessex Garages, proud supporters of Abarthisti
Pages: [1]
Author Topic: Selenia Abarth 10w 50 oil  (Read 1145 times)
aphilpot
Assetto Corse Member
« on: August 29, 2010, 05:00:51 PM »
ReplyReply
Do the garage put this oil in during the service, if not where do you buy it from and if your supplying your own oil do they knock this of the service charge  Huh?
Logged
Andrew
AGP Board Moderator
Global Moderator
S2000 Member
« Reply #1 on: August 29, 2010, 05:05:47 PM »
ReplyReply
Lloyd has supplied his own oil before and yes it was discounted from the charge. Try your local Fiat / Abarth dealer for it, or shop4parts.co.uk
Logged
S2000 Member
S2000 Member
« Reply #2 on: August 29, 2010, 05:19:19 PM »
ReplyReply
the dealer will supply this oil to service the SS but it might not be the cheapest way of getting it.
2 litres was £16.72 at gaydon yesterday so i bought 2 tins to cover my next oil change.
as it comes in 2 litre tins and the service uses 3.3 litres they should return to you the unused oil.
my last service at petches used my own oil, although it did originate from petches, i bought it earlier when they were doing it at a good price and i thought i would need oil for topping up, my last punto would run out between services. as it happens the AGP has not used a drop between 6000 mile changes. Thumb Up
Logged
aphilpot
« Reply #3 on: August 29, 2010, 08:44:43 PM »
ReplyReply
Yeh 2 litres on shop4parts for £15.84 so £31.68 for the 2 tin which is good  Thumb Up but the postage to the Channel Islands is £19.95 so not so good  Thumb Down Why how much extra do the Garage charge to use this oil or should they just automatically use it on an SS  Huh?
Logged
S2000 Member
S2000 Member
« Reply #4 on: August 30, 2010, 08:53:05 AM »
ReplyReply
they should use it automatically on the SS, its specified in the service book, but i'd check with them, most dealers haven't read the book Thumb Up
Logged
Pages: [1]
Jump to:
Copyright & Credits
Powered by SMF 1.1.16
