Corkills Abarth
Author Topic: Soft suspension worries?  (Read 1931 times)
matrix neil
  • Italians do it better!
« on: June 03, 2011, 02:46:41 PM »
Hi all, just a query with yourselfs. I have had my agp ss now for two years and since I had the ss kit put on almost a year and a half ago I have noticed that the ride has always been really hard. Just lately the suspension seems to have become really soft and spongy? Is there any reason for this? I have checked the obvious,tyre pressures, but still the ride feels different? I always slow down for speed ramps and avoid pot holes as best I can, so I can't imagine what it is? Do I need to worry about this? Has anyone else had the same problem? Please advise my fellow abarthians  ???
Grande Punto Abarth,White,SS kit,Sunroof,No stickers,Just looking georgous as she is.
GTMartin
  • 500 Board Moderator
Re: Soft suspension worries?
« Reply #1 on: June 03, 2011, 02:51:12 PM »
Have a look at the dampers (shock absorbers) do they look as if they are leaking fluid?
How many miles have you done?
A84RTH
« Reply #2 on: June 03, 2011, 03:03:54 PM »
Seems strange, what make Tyres have you got on it?
:)Kim & Anthony:)
Theredone
« Reply #3 on: June 03, 2011, 03:07:29 PM »
The top mounts under the bonet have a look at them while someone else turns the wheel they shudnt move
TMC-Motorsport
« Reply #4 on: June 03, 2011, 03:08:49 PM »
I heard top strut mounts give problems. Could be the cause.
matrix neil
« Reply #5 on: June 03, 2011, 06:07:20 PM »
I have done 15.500 miles and it's only just started to happen. It feels like the agp standard before I had the ss kit put on?
matrix neil
« Reply #6 on: June 03, 2011, 06:08:26 PM »
The tyres that came with the kit pz Nero.
Hawk
« Reply #7 on: June 03, 2011, 11:34:14 PM »
I would imagine that one or more shock absorber has failed/is failing.  They tend to get get weaker with age.
Is the car sitting level? If not then check the springs to see if one has broken.
Can't see it being the top mounts to be honest, they do fail frequently but normally just cause noise and maybe a slight bit of movement, not enough to make you think your suspension has gone soft.
Other thing is tyres, some makes have very soft sidewalls but if you haven't recently changed them then it rules that out.
As for trying to pinpoint where the problem is, does it feel softer when cornering one way more than another? When braking does one side of the front dip down more than the other?  Another good test for the rear suspension is to drive at a few miles per hour and slowly apply the handbrake firmly but not enough to lock the rear wheels, does one side of rear of the car dip down more then the other?
Good luck   :thumb:
danrae
« Reply #8 on: June 04, 2011, 10:06:18 AM »
mines is the same handles like a sack of tatties
Abarth Punto 2008, Climate Control, Leather Seats, cd autochanger
matrix neil
« Reply #9 on: June 04, 2011, 10:46:54 AM »
I will try everything that has been suggested. And many thanks for all your replies :-) watch this space.
Old Boy
« Reply #10 on: June 06, 2011, 12:16:11 PM »
Likely to be knackered shock(s).  I've had mine replaced 3 times and it's just done 25k.
They're crap quality for the stiffer springs the SS has :thumbd:
matrix neil
« Reply #11 on: June 06, 2011, 10:01:46 PM »
I went to my dealer today and he road tested the car and admitted there was a problem and he adjusted the balancing of the front suspension electronically. And told me I had too much psi in the tyres. I had 37 psi in the front and 33 psi in the back. I got these pressures off this site, but was told this is incorrect. The correct pressures are 33 in the front and 30 in the rear. The technician has told me there is no leaks or damage to the shocks? But the ride still feels the same? I really don't know what to do? Is it the springs? The technician did road test the car and said it was fine,but I know from driving it home that it doesn't feel the same,still spongy over speed ramps ect? ???
« Reply #12 on: June 06, 2011, 10:07:14 PM »
your figures come from the SS supplement for the 18" wheels, where do theres come from?
matrix neil
« Reply #13 on: June 06, 2011, 10:24:54 PM »
Lloyd I wish I knew, but the technician assured me that 33 for front and 30 for rears! He told me that is what abarth recommend and that running the tyres on the pressures I was running,would do more harm than good!! I did ask the question on here and I assumed that was correct? I'm still thinking to get the springs changed as I'm not happy with the ride still  :'(
« Reply #14 on: June 06, 2011, 10:30:26 PM »
i use the pressures abarth give in the handbook and have no problems, tyre wear is very even and they are lasting well, don't know where they get different figures from, my dampers have done 29000 miles and the SS springs have done 24000 so far. ride is hard as ever  ;D
have you got the SS supplement to show them?, its on the forum with all the other handbooks :thumb:
