Donnelly BrosDonnelly Bros, proud supporters of Abarthisti
Pages: [1] 2
Author Topic: Warranty work on the car  (Read 890 times)
azbo87
Assetto Corse Member
« on: August 29, 2010, 09:42:37 PM »
ReplyReply
Had my car in for warranty work for the second time had loads of issues mainly very little problems they managed to sort out the seal around the top of the engine bay and the creaking doors the other day.
They then said it needs to go back in they want to change the brake pads again so it's going onto it's third set, they said this was now the new fix to the squealing brakes but they didn't mention about my wobbly brake pedal or the grinding feeling through the pedal (which is not ABS) I am bit suspicious of that.
Need new suspension mounts, new sideskirt as it's coming away at either end and a new rear side window as I recently noticed the vertical seal on it was misaligned and rubbing with the seal around the front door causing it to tear.It only looks like a seal which probably cost about 50p aswell just seems silly that a new window is needed because it was misaligned, have not heard of anyone else with this issue of a misaligned window seal.
I did also ask for the lane changer to be removed as it is a safety hazard got fed up with people pulling out in front of me because of it. Turns out this can't be removed which I think is stupid but they did say they did make an update and it does seem less responsive.
Logged
S2000 Member
S2000 Member
« Reply #1 on: August 30, 2010, 08:47:37 AM »
ReplyReply
the side window seal is going on mine and a few others i have looked at, i also assumed it was just a bit of rubber but wondered why no one could track down a part number for it, now i know its part of the window Thumb Up
Logged
Tha_Ben
S2000 Member
« Reply #2 on: August 30, 2010, 01:23:56 PM »
ReplyReply
I'm waiting for side skirts to turn up... Mine were coming apart too. Top mounts have been done. Window seal had gone so had a new window too. Lots of rattles fixed. New instrument cluster has been fitted. Awaiting on new wheel nuts as mine are rusty.... Awesome build quality ;-).
Logged
Melanabb
Esseesse Member
« Reply #3 on: September 01, 2010, 06:56:28 AM »
ReplyReply
My car is only 6 months old and thankfully only the B-pillar card was loose, it just needed to be pressed back... Hope it continues to be trouble free  Wink
Logged
shrekabarth
Esseesse Member
« Reply #4 on: September 01, 2010, 10:05:21 AM »
ReplyReply
mines had new suspension mounts, new gearbox bearings, new alternator, dash board trim replaced, brake mod twice, fan belt replaced, creaking from rear - door latches modified 3 times. glove box latch faulty...
so not too much  Roll Eyes
all ok atm though i did spot the nearside sideskirt at the back was a bit loose when i washed it at the weekend. all looked bolted on ok, had just come abit adift frm the car.
Logged
stevey293
Guest
« Reply #5 on: September 01, 2010, 10:53:30 AM »
ReplyReply
mines had brakes done 3 times new window as well.
gear box is faulty (sounds like stiring a bag of spanners ATM) steering rack knocks when doing full left or right locks. Tried to change the spark plugs last month to find that one is stuck in!!! keep getting coolant leaks.
But still enjoying the car.
Logged
Blanshard
Abarth Wannabe
« Reply #6 on: September 01, 2010, 11:49:49 AM »
ReplyReply
azbo87,
You said you have this problem when braking:
"They then said it needs to go back in they want to change the brake pads again so it's going onto it's third set, they said this was now the new fix to the squealing brakes but they didn't mention about my wobbly brake pedal or the grinding feeling through the pedal (which is not ABS) I am bit suspicious of that."
Ive also have the same problem in my AGP.  I too can feel the grinding when braking at low speeds, and as you say its definately not the ABS.  Did they discover what the problem was?
Logged
ashley_r_84
S2000 Member
S2000 Member
« Reply #7 on: September 02, 2010, 09:35:17 PM »
ReplyReply
Mine went in today to have some stuff checked under warranty - Most of which has been mentioned in this thread....Sideskirt has already been replaced once but is coming away again, Instrument panel is rattling, Rattling from the rear of the car and also steering/suspension feels a bit iffy (good with technical stuff me  Embarrassed )
 Anyways they had my car for 5 hours and didn`t even bother looking at it!! Oh and they forgot to do the oil and filter change that it was booked in for Angry
Amazing customer service as well as build quality!
Logged
CHICKEN & MEAT RACING.
crazyinstructor
« Reply #8 on: September 03, 2010, 07:35:11 AM »
ReplyReply
hey,
Mine goes through brake pads like they're chocolate - I know I teach in it but it's on it's 3rd set. I had a grinding clutch pedal - don't know if it's same as yours but after a massive battle I got them to sort it under warrenty, turns out the clutch pedal had cracked!
They tried to blame my dual controls which is a load of BS - I complained to Fiat UK which was a total waste of time.
H
Logged
speed never killed anyone, suddenly becoming stationary, that's what gets you!
gorrie
« Reply #9 on: September 03, 2010, 08:35:15 AM »
ReplyReply
There's another thread on here about a guy with a broken clutch pedal...  3 times he's had it looked at.  Have a search...  I'm sure he's getting a new design of pedal to fix it or something.
Logged
BN White, Red leather, Climate, 17" 10-spokes, BMC Filter & Ragazzon Exhaust Smiley
GTMartin
500 Board Moderator
Global Moderator
S2000 Member
« Reply #10 on: September 03, 2010, 11:50:31 AM »
ReplyReply
Just made me wonder, how many emergency stops every day? I take it you have to pay because it is wear and tear.
Martin
Logged
crazyinstructor
« Reply #11 on: September 03, 2010, 01:00:58 PM »
ReplyReply
Martin
As few as possible - and how do you do emergency stops if you think it'll brake the clutch pedal?Huh??
No they did it under warranty.
Logged
azbo87
« Reply #12 on: September 13, 2010, 04:47:15 PM »
ReplyReply
Not been on for awhile so sorry for the late reply just wanted my mind off the car for abit the car goes back in on the 21st.
I have had a few concerns over the brakes with the strange grinding feeling and the brake pedal has quite a sideways wobble aswell but they seemed very vague about the brakes when I went to pick the car up.
I've been trying to keep my mind off the car for abit hence why I've not been on because I did worry that maybe it was similar to the clutch pedal problem and I had lost abit of confidence with the brakes.
But the way they did not give too much information out has had me thinking when the brakes originally went in for the shims and replacement pads that maybe they were not correctly fitted (this was a possible cause of grinding feeling through the brake pedal when I researched it) I don't want to say this is the case because this could be wrong and could be a problem with the actual pedal.
Just had hoped I was given more information.
Logged
pvr
Esseesse Member
« Reply #13 on: October 19, 2010, 05:04:39 PM »
ReplyReply
Are you guys just "lucky" that you are near a dealer?
Considering my "local" dealer is two hours away, how would you get around these sort of issues as you don't want to drive for 4 hours just to fix a small thing, let alone multiple visits to fix real issues?
Logged
BMW Z4M, X5, Golf Clipper, Abarth 500C and a runaround Polo ...
DraigFlag
Guest
« Reply #14 on: October 19, 2010, 05:09:35 PM »
ReplyReply
There isn't a way around it really, I'm the same, had to make multiple trips to my "2 hour away local dealer" when mine went wrong. The worst one was when they told me the car was ready for collection, when i got there, it wasn't, i had to drive back in the crappy car they gave me. I gave up by then and told them they could deliver it to me instead. They did!
Logged
Pages: [1] 2
Jump to:
Copyright & Credits
Powered by SMF 1.1.16
