Lipscomb Abarth
Author Topic: Wont Start  (Read 553 times)
njay
Wont Start
« on: December 01, 2011, 08:12:24 PM »
Hi as driving today loads of warning lights came on and lost the speedo so no idea how fast I was going then a few miles down the road the car cut out and was turning over but would not start. Called AA out could not find fault checked spark plugs, fuel and fuses no luck had to have it towed to garage in shock as always looked after it and only done 30k and two years old. The battery is fine before anyone asks. Any one got any ideas?
John501
Re: Wont Start
« Reply #1 on: December 01, 2011, 08:19:47 PM »
Symptoms sound like a snapped cam belt but that would be a worst case senario.
njay
Re: Wont Start
« Reply #2 on: December 01, 2011, 08:20:56 PM »
Cam belt fine
w18bla
Re: Wont Start
« Reply #3 on: December 01, 2011, 08:21:30 PM »
AA would have known if the cam belt had snapped and turning it over with it snapped you would know.... Could be anything, Garage will know best.
Never Stare At The "WIBBLA" You Will Turn To Stone... Abarth 500 esseesse 160bhp - Monza Exhaust (Call The Fire Brigade)- Full Koni FSD - BMC Filter - Blow Off Valve Mod - Woooosssshhh Bang.
njay
Re: Wont Start
« Reply #4 on: December 01, 2011, 08:24:32 PM »
Just as I was trading it in lol typical
shadyracer
Re: Wont Start
« Reply #5 on: December 02, 2011, 12:17:27 AM »
Just cured the same symptoms on mrs shadyracer's alfa gtv.
Crank position sensor was to blame, needed a diagnostics scan to erm, diagnose it. :)
njay
Re: Wont Start
« Reply #6 on: December 02, 2011, 02:01:26 PM »
Abarth are letting a fiat garage do the work have they finally come to their senses that there is not enough Abarth garages?
njay
Re: Wont Start
« Reply #7 on: December 05, 2011, 04:29:30 PM »
Found fault two wired touching under handbrake the previous owner had removed interscope system and fitted own system and did not bother to remove wires so cut them not happy but at least its ok now will cost £100 so not too bad as sold it any way.
