car sits much lower, but the bilstien coilover setup makes the ride even harsher than it already was with a normal setup, I went for a 16" rim and thicker tyre to try to compensate but its still as harsh as
on the plus side the thing corners much better on the bilstien setups, i am told there are two coilover packages from them, one is adjustable for damper firmness too, if you are thinking of it that may be worth the extra money.
There is a local car with a KW fully adjustable setup over here and it has a much nicer ride and handles on par, so does the 695 I tried on FSDs and lowered springs, both options would probably be more forgiving unless the car is used solely on motorways or track.
8200
How does the Bilstein set-up compare to the normal suspension? What are the pros and cons?
