cmguk22
Esseesse Member
« on: August 04, 2010, 10:46:02 AM » |
Reply
How is a 0-60mph time obtained? Am I correct in thinking when a car manufacture performs the test they are not allowed to exceed a certain RPM's limit prior to pulling away. I hold the rpm's at peak torque and then releasing the clutch and get considerably better results than the published values, but I dont expect to get too many miles out of my clutch
Logged
NinjaUK
« Reply #1 on: August 04, 2010, 12:14:48 PM » |
Reply
What time did you get?
Logged
cmguk22
Esseesse Member
« Reply #2 on: August 04, 2010, 01:26:15 PM » |
Reply
<5 sec.
Well to be honest I was timing, it was my Father who was driving (Ex Rally Cross Driver).
Logged
Hoops
Assetto Member
« Reply #3 on: August 04, 2010, 02:06:32 PM » |
Reply
How was it timed? Sub 5 seconds would be very impressive
Logged
cmguk22
Esseesse Member
« Reply #4 on: August 04, 2010, 02:20:26 PM » |
Reply
I timed, and counted down, 3, 2, 1, GO
My Father held the revs at 3500 rpm, With Sport mode and TTC turned on, and when I said GO we shot off.
Just watch the Stig on Top Gear when he does his power laps or look for Rally footage on You Tube, it is common practise. I don’t see why every one on here can not get similar figures.
Logged
Filthypig
« Reply #5 on: August 04, 2010, 02:27:38 PM » |
Reply
Muhahahahaha
Are you spelling Mississippi inbetween counting 1,2,3,4 & 5?
Regardless of your dad being a former rally cross driver or not. A standard (I'm assuming your car hasn't had the same work that LagerLouts has? 220+ BHP) will never hit 0-60 in < 5 seconds unless it's dropping off a cliff.
By all means please prove me wrong by recording it and putting it up on Youtube or somewhere similar.
Logged
Old Boy
Guest
« Reply #6 on: August 04, 2010, 02:28:35 PM » |
Reply
I suspect your stopwatch needs replacing. No way would the GPA get under 5 seconds.
Logged
gorrie
« Reply #7 on: August 04, 2010, 03:22:55 PM » |
Reply
Or your speedo is maybe waaaay off. Best use a datalogger of some kind for accurate readings of stuff like this. To put in perspective, I used to own a 600kg Kit car with a 1.8zetec putting about 160bhp out (so 260bhp/ton). It was running a slightly lower ratio diff, to help with acceleration. The SPA instruments in it had built in 0-60/0-100/qtr-mile capture settings.... and I was lucky if I could crack 4.5secs in that.
« Last Edit: August 04, 2010, 03:31:05 PM by gorrie »
Logged
BN White, Red leather, Climate, 17" 10-spokes, BMC Filter & Ragazzon Exhaust
cmguk22
Esseesse Member
« Reply #8 on: August 04, 2010, 03:29:29 PM » |
Reply
Muhahahahaha
Your correct it is a 100% standard A500 SS. We did it four times as we did not beleve it either, that is why I asked the question in the first place.
Logged
cmguk22
Esseesse Member
« Reply #9 on: August 04, 2010, 03:30:40 PM » |
Reply
It is an Omega, serviced at christmas.
Logged
cmguk22
Esseesse Member
« Reply #10 on: August 04, 2010, 03:31:33 PM » |
Reply
Or your speedo is waaaay off. Best use a datalogger of some kind for accurate readings of stuff like this.
Good Point, that was what I was thinking of next.
Logged
DraigFlag
Guest
« Reply #11 on: August 04, 2010, 04:56:45 PM » |
Reply
Are you sure the wheels weren't just spinning and making it look like you were doing 60? I used to do this with hand brake turns on wet grass, "Look we're doing 60 MPH hand brake turns!"  I reckon my 0-60 time is less than 7 seconds after the TMC box, probably closer to 6.5 actually, but mine is a tad "run in" shall we say! My average time when the car was standard was around 7.5 seconds.
Logged
Old Boy
Guest
« Reply #12 on: August 04, 2010, 05:43:29 PM » |
Reply
Power to weight would give a good ballpark. Assuming 1.2tonne plus driver and passenger and a perfect traction start, you'd need over 300bhp to get under 5 seconds. Given the 500A has 135bhp it should be about 7.5 seconds and the SS with 160bhp around 6.5 seconds with a perfect launch. My track car has over 375bhp per tonne and I struggle to get under 4 seconds (absolutely perfect launch would see 3.4 seconds if I didn't care for the clutch or driveshafts). Would be very interesting to see datalogger info and video. I suspect sales of the SS kit would dramatically increase if your data could be verified.
Logged
mightydquinn
S2000 Member
S2000 Member
TMC 230 bhp
« Reply #13 on: August 04, 2010, 06:12:20 PM » |
Reply
the vi monitor has a 0 to 60 timer i will have to do it one day. unles any other vi owners have tried it...
Logged
