Author Topic: 595 165 misfire cylinder 2  (Read 493 times)
Offline Kryts595
    • UK
« on: January 25, 2020, 06:47:29 pm »
2019 595 with 1000 miles on clock. Took to tuning garage and they couldn't complete full dyno run because of a misfire in CYL2 under load above 5500 rpm.
couldn't replicate it on the way home, but he said its there. Anyone had the same issue?
Will check spark and coils and compression if needs be.
    Online 124Abarthreplica
    Re: 595 165 misfire cylinder 2
    « Reply #1 on: January 25, 2020, 07:11:06 pm »
    Perhaps the spark plug is faulty.
    Try swapping plugs/coils to see if faults moves but if you cannot replicate, it's difficult!!
    Maybe no fault at all?
    Offline Kryts595
      • UK
    « Reply #2 on: January 25, 2020, 07:13:50 pm »
    I'll try and replicate it a bit more but a gave it a good going on the 2hr drive home and nothing. Maybe dyno specific load conditions?
    See how it goes and maybe just replace the plugs for peace of mind. Just hoping its that and not compression  :-X
