Author Topic: Abarth 500 gearbox  (Read 385 times)
Offline Rivill
    • Australia
Abarth 500 gearbox
« on: October 13, 2021, 09:35:41 am »
This may be a dumb question but I’m just trying to weigh up my options. I own a 2012 Abarth 500c with the automatic/dualogic transmission, my mechanic just informed me that I require a new gearbox. The only problem is that I’m from Australia (I know this a UK forum) so sourcing a used gearbox is proving difficult and I would prefer to not have to buy a new one from Fiat as they are very expensive over here.
My question is, are there any alternative gearboxes that I could source that would do the same thing (e.g a standard fiat 500 gearbox)?
    Re: Abarth 500 gearbox
    « Reply #1 on: October 13, 2021, 10:30:53 am »
    Hi Rivill and welcome to Abarthisti :wave:
    Has the gearbox actually failed mechanically or does the Dualogic/MTA actuator cause the problem?
    Offline Rivill
      • Australia
    « Reply #2 on: October 13, 2021, 10:46:22 am »
    The gearbox has mechanically failed from what my mechanic has told me. So I require a new gearbox
    « Reply #3 on: October 13, 2021, 12:16:20 pm »
    AFAIK. the internals are the same as is the clutch on the manual A500 gearbox.
    So maybe a used A500 manual gearbox can be stripped for parts?
    Offline Rivill
      • Australia
    « Reply #4 on: October 13, 2021, 12:23:52 pm »
    That could be a good alternative if I’m unable to locate an A500 auto gearbox.
    Is there much difference between a Fiat 500 1.4 sport (dualogic) gearbox and an A500 dualogic gearbox?
    If I’m unable to locate either A500 gearbox in Australia as they (A500’s) are a very uncommon car here
    « Reply #5 on: October 13, 2021, 08:05:11 pm »
    Sorry to say I don't know :whistle:
    The engine block is much the same between the 1.4 sport and the A500.
    So I would think the gearbox casing would be the same as to the innards :whistle:
    Maybe the same but I would assume the final drive ratio is different.
    Worth a look I would think :thumb:
    Offline imad4u
      • Brisbane Australia
    « Reply #6 on: October 15, 2021, 11:46:50 pm »
    what is the issue that you are experiencing with your gearbox ?
