Author Topic: Asr abs ttc esp c1213-45 problem  (Read 536 times)
Offline corsak
    • Netherlands Delfzijl
« on: October 30, 2021, 02:05:40 pm »
Hi question i have code c1213-54 abs problem.
When I do a scan with the Multiecuscan it shows this code, what should the braking system be on ABS or ASR or ESP that mine is on abs is this correct.
I have already tried to calibrate it and then a proxi but the abs light comes on again after 10 seconds and there is again abs problem in the tft cluster.
Does anyone know what could be the problem could it still be an abs sensor? ??? ???
    Offline mj2k
    Re: Asr abs ttc esp c1213-45 problem
    « Reply #1 on: December 06, 2021, 12:26:50 pm »
    I think C1213-54 might be 'system configuration error' so looks like the proxy alignment might not have worked. According to a quick google it looks making sure ASR is turned off in multiecucan (or on if it's currently off) before running the proxy alignment might work, have you replaced any components like ECU, BCU or ABS pump recently?
