Author Topic: Boot opening issue  (Read 924 times)
Offline soutermcgavin
    • Dunfermline
Boot opening issue
« on: February 21, 2019, 07:24:37 am »
Hi all,
At the moment my boot will only unlock using the button on the key. If I just unlock the car and use the boot catch with my hand it doesn’t open.
Has anyone experienced this at all?
Any advice on the problem and the solution?
Murray
    Offline Filthypig
    Re: Boot opening issue
    « Reply #1 on: February 21, 2019, 07:13:24 pm »
    The wiring will have frayed where it comes through to the boot. Only fix is to repair the wires and it'll work again. You can get repair harnesses online so if your handy with a soldering kit you can fix easily yourself.
    Otherwise its off to an autoelectrician to sort.
    Offline Richard H
      • North Herts
    « Reply #2 on: February 22, 2019, 09:06:43 pm »
    Its often the wiring issue.
    We had the same and it was the switch on the boot itself and the chrome switch/handle were replaced under warranty
    Offline Borderline
      • Scottish Borders
    « Reply #3 on: March 02, 2019, 04:06:34 pm »
    Apparently this a well-known issue with all versions of the 500. It's worth trying a little trick before replacing the switch or indeed the wiring. Use a can of compressed air (sold online for cleaning keyboards) to have a good blast around the flap you squeeze to open the boot. The theory is that the switch under the flap gets bunged up with all sorts of road grot and blowing it out may help. This worked on my previous (Fiat) 500 and I'm about to try it on the Abarth (as soon as it stops raining...)
    Offline NateM
      • High Wycombe
    « Reply #4 on: February 14, 2020, 08:39:02 am »
    Great advice, did it work on your Abarth?
    I've had this problem for years and yes, Abarth dealers said new wiring loom at extortionate costs.
    Offline Moose
    « Reply #5 on: February 25, 2020, 09:17:25 pm »
    If it's only the boot catch that doesn't work (ie you can open it with your key) then it's more than likely that the switch pins have worked loose - I have the same issue now and I've yet to fix it, but I think I found a youtube video somewhere. If I find it again, I'll post the link
    Scorpion Black/Gara White Bi-Colour A595 Turismo, black leather and Interscope
    Crossover Black, black leather, white stripes, mirrors and scorpion - Gone, but not forgotten
    Offline R34
      • Costa del sol
    « Reply #6 on: February 26, 2020, 11:19:42 pm »
    Easy repair
    Offline Moose
    « Reply #7 on: February 27, 2020, 07:51:13 pm »
    Youtube vid
