Author Topic: Changing Timing Belt  (Read 862 times)
Offline whizzo944
    • Durham
« on: April 21, 2021, 07:40:54 pm »
Hello All, because I don't know if or when the timing belt has been changed on my car, 2015 595, I am going to change it for peace of mind. I have been looking on the Abarth Workshop website and it looks straght forward
EXCEPT the bit where they tell you to loosen the cam pulley bolt. I have changed timing belts on lots of different cars but none of them needed to have the cam pulley retaining bolts loosened. So, my questions are:-
1 Do I really need to loosen this bolt because I don't understand why?
2 If I really do need to loosen this bolt, can someone please explain why this is necessary?
TIA
Dave.
    Online 124Abarthreplica
    Re: Changing Timing Belt
    « Reply #1 on: April 22, 2021, 10:00:02 am »
    Good morning Dave,
    The camshaft pulley is NOT keyed or fixed to a specific point to the camshaft.
    After locking the camshaft and crankshaft, the camshaft pulley is allowed to rotate whilst the belt is fitted and tensioned.
    Then the pulley nut is torqued up.
    Offline whizzo944
      • Durham
    « Reply #2 on: April 23, 2021, 01:29:07 pm »
    Hello, thanks 124Abarthreplica. I've never seen this in an engine before, relying on friction to drive the cam. Yes, I know that engines that have keys or pins don't drive on the key/pin, but I still don't like it. But at least I now know why you have to do it, so thank you for that.
    Dave.
    Offline 695C
      • Denmark
    « Reply #3 on: April 23, 2021, 02:47:27 pm »
    Can you do a youtube video of the proces so a first timer can see if it is worth having a go at it :-)
    Offline whizzo944
      • Durham
    « Reply #4 on: April 24, 2021, 12:38:33 pm »
    Hello, do you rely on the cam locking tool to hold the cam when you're loosening and tightening the cam pulley bolt?  I would be concerned that I was going to shear the cam locking tool off.
    TIA,
    Dave.
    « Reply #5 on: April 24, 2021, 01:43:55 pm »
    TIA,
    Dave.
    NO, no, no.
    Hold the cam sprocket by another method.
    Offline jl-c
      • Shropshire
    « Reply #6 on: April 24, 2021, 04:24:53 pm »
    TIA,
    Dave.
    [/quote[size=78%]][/size]
    [size=78%]
    [/size]
    [size=78%]favourite is usually old belt round pulley clamped with mole grips and held in the other hand or secured to another solid part of the engine or failing that by a willing helper
    Offline whizzo944
      • Durham
    « Reply #7 on: April 24, 2021, 06:12:54 pm »
    Thought not :-)
    Offline whizzo944
      • Durham
    « Reply #8 on: April 24, 2021, 06:21:05 pm »
    Think the favourite is a long bar with 2 bolts sticking through the holes in the pulley.
