Author Topic: Driveshafts  (Read 1111 times)
Offline BiAS
    • Devon
Driveshafts
« on: September 23, 2020, 07:22:09 pm »
Hi, I've had a search and found a lot of previous threads about driveshafts but couldn't find a definite answer, sooooo....
Are all the 5 gear driveshafts interchangeable?
The wife's Esseesse is an earlier one, there seem to be an early type and a later type but I can't figure if they're interchangeable. If I've read correctly the 6 gear 'shafts are different and not compatible.
If anybody has any clues I'd be most appreciative
Cheers :thumb:
    Online 124Abarthreplica
    Re: Driveshafts
    « Reply #1 on: September 24, 2020, 09:49:37 am »
    Abarth did not fit a 6 speed gearbox to the 500.
    They are all 5 speed.
    Offline BiAS
      • Devon
    Re: Driveshafts
    « Reply #2 on: September 24, 2020, 10:31:03 pm »
    In that case are all the 500s and 595s with a 5 speed fitted with the same C510 gearbox?
    Does this mean that all the driveshafts are interchangeable?
    Re: Driveshafts
    « Reply #3 on: September 25, 2020, 10:43:43 am »
    Offline saxant
    Re: Driveshafts
    « Reply #4 on: March 15, 2021, 01:21:09 pm »
    Hi, did you manage to find out as looking to replace my worn out 2009 Abarth 500 shafts with those from a low mile 2018 Abarth 595. Thanks
    Offline saxant
    Re: Driveshafts
    « Reply #5 on: March 15, 2021, 01:52:32 pm »
    ok, according to buycarparts.co.uk, they both use the same OEM part number - FIAT (55209967), with 25 splines/teeth at the wheel hub end.
    https://www.buycarparts.co.uk/era-benelux/15275890
