Author Topic: DRL/sidelight issue  (Read 430 times)
Offline Jhandy2
    • rushden
DRL/sidelight issue
« on: June 30, 2020, 08:25:29 pm »
So this is my issue has anyone had similar?
I have replaced the housing and the bulbs
Swapped bulbs over with drivers side so I know the bulbs connect and work properly
Checked the fuses and earths
Visually checked wiring.
    Re: DRL/sidelight issue
    « Reply #1 on: July 02, 2020, 11:07:44 am »
    We had the same issue but was tracked down to a poor earth which fixed it. Time to get the multimeter out ;D
    Offline mac1944
      • west lothian
    « Reply #2 on: July 03, 2020, 11:21:22 am »
    Agree check all running lights and bulbs including rear lights, in the old days before ECU’S stop/tail faults used to throw  up all sorts of anomalies, usually bulb or earth fault.
    Offline Jhandy2
      • rushden
    « Reply #3 on: July 03, 2020, 01:03:17 pm »
    that seems like the plan this weekend, and wire in an extra earth to see if it fixes it
