Author Topic: error code u0405  (Read 741 times)
Offline corsak
    • Netherlands Delfzijl
error code u0405
« on: July 10, 2021, 05:18:46 pm »
Hello what problem is this.
I've read that it has to do with the cruise control but it's not on my Abarth 500.
    Re: error code u0405
    « Reply #1 on: July 11, 2021, 08:07:53 am »
    Can you clear the fault code?
    Offline corsak
    « Reply #2 on: July 11, 2021, 08:11:22 am »
    No
    Offline 695C
      • Denmark
    « Reply #3 on: July 11, 2021, 08:20:44 am »
    Do you have cruise control?
    « Reply #4 on: July 11, 2021, 08:42:24 am »
    No
    Is your code reader capable of clearing fault codes?
    Offline corsak
    « Reply #5 on: July 11, 2021, 08:51:05 am »
    no no cruise control and we have tried two code readers but neither of them can clear them.
    « Reply #6 on: July 11, 2021, 09:42:44 am »
    Have you tried this...
    https://www.multiecuscan.net/
    Offline corsak
    « Reply #7 on: July 11, 2021, 10:49:27 am »
    Yes i have.
    « Reply #8 on: July 11, 2021, 04:53:17 pm »
    I would suggest, because of the very unhelpful fault code, you have a non specific CAN wiring fault that will be difficult to trace.
    Were you working on the car when it appeared? Perhaps go back to where you were working.
    Did it appear after a bump against something, over revving, missing a gear change, braking hard, switching the lights on etc etc?
    May have to visit an Abarth dealer to access 'Examiner' diagnostics
    Offline corsak
    « Reply #9 on: July 13, 2021, 07:08:18 pm »
    Okay thanks  :thumb:
    « Reply #10 on: July 13, 2021, 08:29:25 pm »
    Offline 695C
      • Denmark
    « Reply #11 on: July 14, 2021, 09:18:47 am »
    How is the engine running? Smooth? higher rpm at idle? Long shot could be a faulty camshaft sensor. Is the engine warning light on in the display?
    Offline corsak
    « Reply #12 on: July 15, 2021, 06:27:02 am »
    Great thanks  :wave: :wave:
