Author Topic: Gear Linkage Bushings  (Read 549 times)
Offline Roquito
    • Warwckshire
« on: August 07, 2021, 05:08:54 pm »
Hi, I have a Abarth 500, 2010, yep one of the 1st. its done 30plus smile, (miles) now. The the gear linkage is tight and struggles to go into 1st 2nd & 3rd gears, So think, has any one fitted a shortt sh*t, if so which one and also  where did you buy the bushings for both ends of the cabbles.
    Offline shadyracer
    Re: Gear Linkage Bushings
    « Reply #1 on: August 10, 2021, 06:26:05 pm »
    If you use search function and type short shift, should be some relevant info there maybe of help to you
