Author Topic: Gear ratios  (Read 10908 times)
Offline ChrisM
Gear ratios
« on: January 12, 2009, 01:10:17 pm »
I tried searching but could not find any information on the gearing, either here or generally on the web. Does anybody have any details of the gear ratios and what RPM the Abarth is doing in 5th gear at 70-80-100 MPH ? Wanted to get an idea of what it's like cruising on the motorway/superstrada etc.
ChrisM
    Re: Gear ratios
    « Reply #1 on: January 12, 2009, 01:13:20 pm »
    Chunky would be the best one to ask, i'm sure he can get it off e-learn. He doesn't have access to the forum at work though so it will be tonight before he can get to you.
    Offline euroboy
    • An Englishman in Holland
    Re: Gear ratios
    « Reply #2 on: January 12, 2009, 04:45:21 pm »
    The only thing I remember is that 200kmh (125mph) the wee engine is revving around 5000.  So you can count back a wee bit and a guesstimate 100mph is about 400rpm (although I am sure the definate figures will show up later).
    I did 1200 miles in it on the motorway last week, driving from Maastricht in Holland to Hull, UK and back again in 3 days and it didnt make me feel overly tired or cramped etc.  Pretty good fun actually!
    Abarth 500
    G-tech 'S' chip.
    G-tech full exhaust sytem.
    172bhp & 285Nm @4850rpm.
    Now sold - doh!
    chunkymonkey
    Re: Gear ratios
    « Reply #3 on: January 12, 2009, 04:57:18 pm »
    1 - 3.818
    2 - 2.158
    3 - 1.475
    4 - 1.067
    5 - 0.875
    6 - 0.744
    R - 3.545
    Re: Gear ratios
    « Reply #4 on: January 12, 2009, 05:31:32 pm »
    Thanks Chunky, knew you'd have the info
    Offline euroboy
    Re: Gear ratios
    « Reply #5 on: January 12, 2009, 05:36:42 pm »
    That must be for the GP - as the 500 is only a 5 cog box.
    Abarth 500
    G-tech 'S' chip.
    Now sold - doh!
    Re: Gear ratios
    « Reply #6 on: January 12, 2009, 05:37:52 pm »
    Good spot Euroboy, I missed that. Is the flue blurring your eyes again Chunky?
    Offline Reteb
    Re: Gear ratios
    « Reply #7 on: January 12, 2009, 06:10:42 pm »
    And don't we need the final drive ratio to translate these numbers into something meaningful?
    chunkymonkey
    Re: Gear ratios
    « Reply #8 on: January 12, 2009, 07:44:44 pm »
    oops, sorry it didnt say in the original post what car and as ive only worked on GPA's i keep defaulting to them.
    cant get back into e-learn at the minute.
    chunkymonkey
    Re: Gear ratios
    « Reply #9 on: January 12, 2009, 08:04:02 pm »
    1 - 3.909
    2 - 2.238
    3 - 1.520
    4 - 1.156
    5 - 0.872
    r - 3.909
    final drive - 3.353
    chunkymonkey
    Re: Gear ratios
    « Reply #10 on: January 12, 2009, 08:05:41 pm »
    oooh, no smiley?  :-\
    Scrogg
    Re: Gear ratios
    « Reply #11 on: January 12, 2009, 08:14:00 pm »
    oops, sorry it didnt say in the original post what car...
    Posting the thread in the 'New 500 Abarth' section should have given you a bit of a clue though ;) :P
    Offline simer
    Re: Gear ratios
    « Reply #12 on: January 12, 2009, 08:19:08 pm »
    1 - 3.909
    2 - 2.238
    3 - 1.520
    4 - 1.156
    5 - 0.872
    r - 3.909
    final drive - 3.353
    Any idea how that translates to mph/1000rpm in each gear?
    chunkymonkey
    Re: Gear ratios
    « Reply #13 on: January 12, 2009, 08:21:52 pm »
    yep, just seen how that works! dont normally look at the header page bit, just click on unread posts since last visit.  ???
    mitch_
    Re: Gear ratios
    « Reply #14 on: January 12, 2009, 08:29:48 pm »
    There's not much resembling an overdrive in there.......
