Author Topic: Help please !! Abarth not blowing cold air at all. Only hot  (Read 184 times)
Offline vasjot
    • Burnham, Slough
« on: October 09, 2020, 07:11:22 pm »
Hi all. Hope your doing all well. Just had my Abarth mapped and had the forge induction kit all installed and working correctly. However on the way home tried turning the climate control to lower the temperature but to my surprise car just won't blow any form of cold air. Even with AC on or off it just blows hot air. However much I change the temperature makes no difference so I'm not really sure what to do. It's only happened after the map and induction kit install it that helps. Hope you guys can help. Any help would be much appreciated.
Kind regards
    Offline Richard H
      • North Herts
    Re: Help please !! Abarth not blowing cold air at all. Only hot
    « Reply #1 on: October 10, 2020, 04:15:03 pm »
    I am no expert.
    The heater matrix may have been disturbed.
    Or the flaps that change the air input from hot to old or cold to hot have either broken or jammed in the "hot" position.
    It may have happened when the work was done,
