Author Topic: Monza flap  (Read 1434 times)
Online 124Abarthreplica
Monza flap
« on: August 15, 2013, 08:48:02 pm »
Whilst sorting out my squeaky rear brakes,:whistle:I had a look at the infamous flap.
It was seized solid. :thumbd:
To my surprise in the closed position I believe, with lever to the rear and short spring.
Ten minutes later it was free with the lever going forward stretching the spring.
Can someone confirm that the flap is open with the lever forward and spring stretched?
If this is so, it dispels the notion that the flap always sticks open
I would have thought with the spring pulling the flap closed when the car is not being used , it would naturally seize in this position.
    Re: Monza flap
    « Reply #1 on: August 15, 2013, 09:04:44 pm »
    Yes you are right, when the spring is stretched the flap is open. Coppa slip grease is your friend :thumb:
    Re: Monza flap
    « Reply #2 on: August 16, 2013, 06:30:17 pm »
    Thank you my friend :thumb:
    Offline mutsey
      • surrey
    Re: Monza flap
    « Reply #3 on: August 19, 2013, 01:35:50 pm »
    ive secured mine open permanently !!!
    Grey 595 competizione  , grey leather sabelts ,piaa drls, smoked side indicator lenses
