Author Topic: P1171 code  (Read 439 times)
Offline Johnaitken83
    • County Durham
P1171 code
« on: April 07, 2020, 08:45:33 pm »
As description I have a p1171 code coming up on the reader my car is -25 fuel trim, changed lambda sensors both map sensors crankshaft sensor, checked numerous times for a boost leak or vac leak found nothing, the car is pinging and don’t want to drive it any help would be greatly appreciated
    Offline mac1944
      • west lothian
    Re: P1171 code
    « Reply #1 on: April 09, 2020, 08:17:48 am »
    In the old days this was described as Pinking usually caused by weak mixture and/or ignition timing, you need to get the engine on a proper diagnostic scanner.
    Offline Matt_dab
      • Hinckley
    Re: P1171 code
    « Reply #2 on: April 10, 2020, 05:32:27 pm »
    Did you use good quality lambda sensors?
    As above, it needs putting onto a diagnostics and doing live running.
    Fiat specifies P1171 as "Lambda 1 mixt. strength below cat"
    -25 trim if memory serves right means the ECU is pulling the fuelling back as its running rich!
    Has it been remapped? I would check Injectors and see what each of those are doing
      • County Durham
    Re: P1171 code
    « Reply #3 on: April 22, 2020, 10:36:58 pm »
    Thanks guys sent all injectors off for cleaning it’s still doing it, every sensor and o2 has been genuine Bosch it’s costing a lot now just put new plugs and coil packs in and also a new fuel pump
