Abarth Cars => Abarth 500 => Topic started by: Johnaitken83 on April 07, 2020, 08:45:33 pm
Title: P1171 code
Post by: Johnaitken83 on April 07, 2020, 08:45:33 pm
As description I have a p1171 code coming up on the reader my car is -25 fuel trim, changed lambda sensors both map sensors crankshaft sensor, checked numerous times for a boost leak or vac leak found nothing, the car is pinging and don’t want to drive it any help would be greatly appreciated
Title: Re: P1171 code
Post by: mac1944 on April 09, 2020, 08:17:48 am
In the old days this was described as Pinking usually caused by weak mixture and/or ignition timing, you need to get the engine on a proper diagnostic scanner.
Post by: Matt_dab on April 10, 2020, 05:32:27 pm
Did you use good quality lambda sensors?
As above, it needs putting onto a diagnostics and doing live running.
Fiat specifies P1171 as "Lambda 1 mixt. strength below cat"
-25 trim if memory serves right means the ECU is pulling the fuelling back as its running rich!
Has it been remapped? I would check Injectors and see what each of those are doing
Post by: Johnaitken83 on April 22, 2020, 10:36:58 pm
Thanks guys sent all injectors off for cleaning it’s still doing it, every sensor and o2 has been genuine Bosch it’s costing a lot now just put new plugs and coil packs in and also a new fuel pump
Post by: Alfalfa91 on May 11, 2021, 10:01:13 am
Hi,
Did you get to the bottom of this issue?
I am going through the same troubles unfortunately
