Author Topic: rear slider pin stuck solid, any advice 2009 500 Esseesse  (Read 221 times)
Offline JapspeedUK
    • Winchester, Hampshire
« on: March 02, 2020, 03:36:51 pm »
Hey Abarthests!!
I'm new here and on my 2nd Abarth 500 in 6 months, sold first to get a Mito then changed my mind so now have a 2009 Esseesse, but from Scotland and previously abused IMHO.
So, fitting new grooved and drilled discs, front no issue, but rears!! Oh my days!!
Is there a special way to remove the slider pins? one came out with a bit of a tap, the other is stuck hard, I've increased beating it with a heavy hammer, I've a 16mm spanner C bit behind the bolt head, so not to hit it direct but man, it will not move a millimetre!!
Am I missing something?? I'm not a trained mechanic but kinda know the basics, just did the clutch and flywheel with only minor issues.
PLEASE HELP... As its still jacked in the street.. Thanks in advance
    Re: rear slider pin stuck solid, any advice 2009 500 Esseesse
    « Reply #1 on: March 02, 2020, 04:18:59 pm »
    Does it turn with a spanner on it?
    If not, I suspect it needs a bit of heat.   :thumb:
