Author Topic: "Rotor" sound - warped disc(s) or failing wheel bearings on "standard" 500?  (Read 794 times)
Offline Borderline
    • Scottish Borders
Hi all, being driven slowly mad  :crazy: by an irritating noise I can only describing as sounding like a rotor. Last time I heard anything like it, it was due to a warped disc on my old Alfa - but all four discs on the 500 were new barely a year ago and the fronts must be nigh-on impossible to warp, given the ventilated construction. Rear wheel bearings were replaced in the past 18 months but I know these are boggo FIAT parts, so perhaps the lateral forces of higher cornering speeds  :thumb: cause them to wear rapidly? The sound is most obvious between 20 and 40mph and above 60 but disappears at, ahem, "motorway" speeds  :whistle:. Any thoughts? Is there a more robust wheel bearing available? Gonna be sideways through a hedge soon if one of those babies suddenly lets go, so I'm getting desperate!
    Offline mac1944
      • west lothian
    When the noise is apparent try moving steering from side to side quite hard, does noise go away, or lift wheel place hands top and bottom and try and move it back and forth to see if there is any movement, from previous experience wheel bearings make a growling noise, at high speeds the wheel may centre itself due to centrifugal force and the noise go away.
    Offline Borderline
      • Scottish Borders
    Went for MoT last Friday and came back with six advisories! :thud: Three of them related to slight brake binding, which the mechanic thought could quite well be the source of the deeply annoying rotor sound. To his great credit, he said there was no point in stripping and regreasing the calipers just yet, as the road salt and grit would undo the good work in about a week.
    I'm left wondering why my original boggo Fiat 500 never suffered this affliction; and how many more weeks of cr*p weather will I have to put up with before I can get the brakes serviced? Sigh...
    Offline 695C
      • Denmark
    It sounds like your gliders need greasing - it's actually a pretty good first DIY if you are up for it. It's simple and requires little more than being able to change a flat tire.
    Personally I would do first coming chance if DIY, otherwise wait until you change for summer tires.
    Offline shadyracer
    Im with 695C on this one, the gliders or caliper slides will be sticking, if rubber boots burst, easy for dirt ingress.
    Try not to use any oil based lubricant to get them moving, theres a rubber bush around the slide pin., oil would make it swell. use proper brake grease once pin is out of carrier. Also you'll probably find the rear pads are stuck in carrier, what happens is dirt and rust builds up under the shiny steel anti rattle shims, clean them and remove from carrier to clean below where they sit on carrier.
    Not difficult unless badly seized, but dont leave it too long or your wheelbearings will heat up and wear prematurely :thumb:
