Author Topic: Tyre rotation  (Read 408 times)
Offline A
    • South Oxfordshire
Tyre rotation
« on: October 29, 2020, 08:17:18 am »
Hi everyone.
Should I rotate the tyres as per the info system....the mechanic yellow symbol appeared recently, about 6500miles. I reset it... but am I dismissing something that is important.
I’m not taking the car out on the track, just A124 normal driving :)
Cheers
A
    Offline ArdsAbarthist
      • Ards Peninsula, Co. Down
    Re: Tyre rotation
    « Reply #1 on: October 31, 2020, 09:27:16 am »
    It’s an interesting question; to rotate or not, if the car is driven only on public roads.
    Personally speaking, my public road A124 driving is fairly spirited when the situation allows. I’m sure I wear my rear tyres faster than my fronts, so I have rotated mine to try and equalise the usage.
    As a d.i.y. project it’s straightforward, but I didn’t have enough axle stands to hand so I wimped out and got the dealer to do it at the annual service.
    Perhaps your local Kwik Fit (or similar) would oblige for a small consideration?
    Re: Tyre rotation
    « Reply #2 on: November 01, 2020, 04:01:55 pm »
    On our Abarth 500 fitted with the P Zero tyres, I swapped front to back, to even out the wear. I did swap side to side once and these noisy tyres were really much noisier, I would not recommend it.
    Offline A
      • South Oxfordshire
    Re: Tyre rotation
    « Reply #3 on: November 02, 2020, 11:27:56 am »
    Thanks for the advice. You have both highlighted things I had not thought of and this will be of use to the community.
    Thank you.
    A
