Author Topic: Abarth air filter  (Read 4145 times)
Offline adam1234
    • wales
Abarth air filter
« on: July 25, 2012, 02:32:03 pm »
whats the best air filter to get for my 11plate Abarth punto evo any replies would be much appreciated thanks   :thumb:
    Offline adam1234
      • wales
    Re: Abarth air filter
    « Reply #1 on: July 25, 2012, 02:41:19 pm »
    has any one got a - BMC high performance air filter on there Abarth punto evo much difference ??
    Offline 3k5k
    • Exactly how long is it.
      • Doncaster
    « Reply #2 on: July 25, 2012, 07:21:15 pm »
    Yep, got one on mine, wont hurt having it on, no real power gains.
    You can here the wastegate on the turbo fluttering, which sounds quite good.
    The BMC filter can be cleaned, so you will never need to change it.
    A good upgrade really, unless you change to a full induction kit.
    kEVO
    50 Shades of Campovola
    Offline adam1234
      • wales
    « Reply #3 on: July 29, 2012, 07:37:09 pm »
    ok thanks KEVO have you done anything else to your Abarth to give it a bit more power ?
    « Reply #4 on: July 29, 2012, 10:49:39 pm »
    Esse Esse kit would be a good shout.
    Offline adam1234
      • wales
    « Reply #5 on: July 30, 2012, 09:18:08 am »
    it would but it only gives you like 15 more bhp so  not really worth it in my opinion
    Offline Noddy
      • Leics
    « Reply #6 on: July 30, 2012, 10:11:02 am »
    I've put an ITG panel filter on my A500, was recommended to use one instead of the BMC.  It doesn't really give any extra performance, and only adds a tiny amount of induction growl, but it's not a paper filter so should last a lot longer before clogging up.  :thumb:
    Plus I use them on my rally cars so have some kind of brand allegiance..  :whistle:
    Offline adam1234
      • wales
    « Reply #7 on: July 30, 2012, 10:36:32 am »
    OK thanks would it be the same 1 for the punto ? where is the best place to get one from ?
    Offline adam1234
      • wales
    « Reply #8 on: July 30, 2012, 11:12:57 am »
    what else can i do to give my abarth a bit more power any ideas thanks guys ???? ;D
    Offline Noddy
      • Leics
    « Reply #9 on: July 30, 2012, 12:24:47 pm »
    I bought it when I had my car remapped at Angel, & had it sent directly from ITG.
    An air filter won't give you any more noticeable power, you have to remap/ fit a tuning box/ bigger turbo/ change engine internals for that
    Offline 3k5k
      • Doncaster
    « Reply #10 on: July 30, 2012, 12:52:00 pm »
    Tmc box is a good investment, you should see 200bhp.
    Offline adam1234
      • wales
    « Reply #11 on: July 30, 2012, 02:00:11 pm »
    ok thanks guys   :thumb: i have been looking at the TMC KIT KEVO but not shore will do a bit more research on it
    Offline adam1234
      • wales
    « Reply #12 on: July 30, 2012, 04:10:48 pm »
    has any one done anything different to modify there Abarth punto evo any replies much appreciated  :)
    Offline adam1234
      • wales
    « Reply #13 on: August 01, 2012, 10:05:52 am »
    has any one got there APE to  pop ?  :wave:
    Offline adam1234
      • wales
    « Reply #14 on: August 03, 2012, 11:00:06 am »
    just fitted my new BMC air filter sounds good would recommend it   :thumb:
