Author Topic: APE SS BOV mod - how ?  (Read 8009 times)
Offline M5/Abarth Russ
    • KENT
« on: June 20, 2012, 01:10:44 am »
Has anyone done the blow off valve mod on an Abarth EVO yet. The engine looks different to the AGP although I suspect that is down to the cover.
Also is the bung and filter size 28mm as per the AGP ? I cant find any info the Evo mod and I pick mine up Friday !
« Last Edit: June 20, 2012, 01:16:00 am by M5/Abarth Russ »
2011 Abarth Punto Evo EsseEsse
    Re: APE SS BOV mod - how ?
    « Reply #1 on: June 20, 2012, 08:47:16 am »
    its a different engine in the evo :thumb:
      • KENT
    « Reply #2 on: June 20, 2012, 11:35:52 am »
    I did not realise that. So has anyone done the mod or will I have to blaze a trail first  ;D
      • KENT
    « Reply #3 on: June 21, 2012, 11:45:34 am »
    I cannot believe that no one has ever done a BOV mod on the APE  ???
    « Last Edit: June 21, 2012, 11:55:33 am by M5/Abarth Russ »
    « Reply #4 on: June 21, 2012, 11:53:37 am »
    I can't imagine it'll be too hard to be honest, the turbo is shared with the AGP so it can't be that different
      • KENT
    « Reply #5 on: June 21, 2012, 11:57:26 am »
    I cant find any info at all. There is no difference between the Evo and SS Evo so surely some must have fitted a filter ?
    Offline Gb190
    • APEE convert
      • North east england
    « Reply #6 on: June 23, 2012, 07:26:52 am »
    I don't think you can do it on this engine mate. The bov seems to be attached to the side of the turbo. I have re routes my air intake to the filter box and removed te trumpet inside the bottom part of the airbox and trust me you don't need a bov filter the dump valve and wastegate chatter is plenty loud enough.
      • KENT
    « Reply #7 on: June 23, 2012, 09:02:18 am »
    Excellent - can you give me more details ?
    Offline Gb190
    • APEE convert
    « Reply #8 on: June 23, 2012, 11:11:43 am »
    Pop me a personal message with either yr email or mobile and I'll pop you some photos over. Basically you take the top off the airbox and remove bmc filter, you will then see a trumpet in the bottom of the box. This slides out. Then there is about an 8" long cool air feed pipe coming out of the bottom of the airbox. I took this put and replaced it with about a 5" long 70mm 90 degree silicone bend to bring air up from the big space at bottom of engine. Much cooler it from there and hey presto cooler air more turbo spool, dump whoosh and waste gate chatter noises.
      • KENT
    « Reply #9 on: June 23, 2012, 11:52:45 am »
    You have pm  :thumb:
      • KENT
    « Reply #10 on: June 27, 2012, 10:38:11 pm »
    Hi there.
    Did you email me those pics mate as i cannot find them.
    Russ
    Offline Gb190
    • APEE convert
    « Reply #11 on: June 28, 2012, 08:41:20 pm »
    Hi russ apologies mate have not had chance been crazy busy at work etc. will Defo do them say morn for you. Appologies
      • KENT
    « Reply #12 on: June 28, 2012, 08:55:12 pm »
    cheers mate  :thumb:
    Offline brads91
    • APE
    « Reply #13 on: June 30, 2012, 04:49:25 pm »
    How much louder is it? I'm quite interested too of wouldn't mind posting some pics :thumb:
    Dusty_viper
    « Reply #14 on: July 02, 2012, 07:48:56 pm »
    +1
