Author Topic: Forge "Blow Off" valve install  (Read 7883 times)
Offline stealth
    • Hook, Hampshire
« on: February 24, 2013, 01:52:59 pm »
During the weekend I installed a Forge "Blow Off Valve", sounds lovely:  :) :)
Forge Webpage:
http://www.forgemotorsport.co.uk/content.asp?inc=product&cat=060202DV&product=FMDVF14A
    Offline Bonila
    Re: Forge "Blow Off" valve install
    « Reply #1 on: March 06, 2013, 12:27:10 pm »
    Any chance of vid to hear what it sounds like? How easy was it to install?
    APE SS - White with Red Stripes
    Offline stealth
      • Hook, Hampshire
    « Reply #2 on: March 09, 2013, 06:38:50 pm »
    It was quite a straight forward part to install, the most annoying thing were the pictures from "Forge" arrived  in "B&W" (I could not work out what pipes had to be either changed / removed or cut), found the pictures in colour, everything became eaiser.
    I've asked "Forge" to send out colour & not "B&W" install pictures to buyers for this part.
    I'll upload a video of what the valve sounds like soon.
    Dusty_viper
    « Reply #3 on: May 17, 2013, 01:53:32 pm »
    Yer i'd be interested to hear what this sounds like.
    Offline FWD_Boy
    • FWD is the way FORWARD!!!
      • Dartford, Kent
    « Reply #4 on: June 16, 2013, 10:46:16 pm »
    Look forward to hearing the difference between the Punto BOV and the one I have on my A500
    FWD_Boy - AKA 'Chris'
    Offline stealth
      • Hook, Hampshire
    « Reply #5 on: June 20, 2013, 10:21:43 pm »
    I might be attending the Ace Café's Italian cars event (2nd Thurs of each month) in Aug & might be going to Brooklands event so can show anyone who wants to hear what it sounds like.
    Offline KrystenCTR
    « Reply #6 on: July 31, 2013, 09:54:03 pm »
    You can have something similar without replacing the whole electronic Blow Off Valve.
    Forge do a Spacer for exactly this.
    Check this out
    http://forgemotorsport.co.uk/content.asp?inc=product&cat=&product=FMSPF14A
    « Last Edit: August 01, 2013, 08:30:25 am by GTMartin »
    Lazing next to that Redline
    Offline euan1234
      • Fife
    « Reply #7 on: August 20, 2013, 04:16:56 pm »
    Check this out
    Ver-ry tempted....  ;D
    Offline FWD_Boy
      • Dartford, Kent
    « Reply #8 on: September 11, 2013, 01:29:50 pm »
    Seeing as the Puntos already make a bit of turbo flutter under off throttle revving Id imagine they make abit more noise than the A500 Forge BOV
    Offline pasqy88
      • bedford
    « Reply #9 on: June 09, 2014, 02:11:42 pm »
    Check this out
    Anyone have this spacer fitted and have a video to what it sounds like?
    Offline FullMetalScorpion
    • APE Supersport+
      • A Small Town In Sheffield
    « Reply #10 on: June 09, 2014, 04:48:21 pm »
    I was interested in an atmosphere blow off valve. However when I read the fitting instructions on the Forge item and realised how much I would have to butcher the pipes on the car I lost all interest. I then found the adapter plate and I think thats a much better idea. An even better idea is the same sort of item sold by an Italian firm. It has an adjuster on the side which allows you to turn it off or on. It also enables you to basically "adjust the volume" by selecting how much is expelled to the atmosphere. The video for that item is below.
    Does anybody know why the guy takes off all the pipes? Was it just to make it easier to show what he's doing as I don't think it was necessary.
    « Last Edit: June 09, 2014, 04:51:16 pm by FullMetalScorpion »
    Offline Lethal
      • Lancashire
    « Reply #11 on: June 09, 2014, 10:22:48 pm »
    I have one fitted and it is very noticeable. Easy to fit as well.
