Im abit confused about how to get a safe flush fit, ive done some measurements but round here its hard to find level ground and so its not the same clearance on both sides but i moved the car around abit and got it close and took more than 1 measurement and i am thinking averaging to the middle should work out? Because closer i gotto level ground the numbers got closer in towards the middle average value and these are pretty close now i think. Anyway here are my measurements (all in mm):
(Left front/Right front
Left rear/right rear):
Number1:
15/18
27/28
Number2:
15/18
27.5/27.5
Number3:
18/14.5
27.5/29
Based upon these measuremtnes what spacers would you recomended front and rear?
Sizes i can get here are 5,12,16,20,22,25,30mm (last 3 slightly more expensive)
I was thinking front 12mm and rear 25mm as i dont want the front to be wider than the rear just in case. This sound reasonable is it gonna be safe enough?
