Author Topic: has any one had there standard APE rolling rollered then with a tmc kit fitted ?  (Read 1787 times)
Offline adam1234
    • wales
any replied much appreciated  getting mine done 6th march  ;D :thumb:
    Offline Andrew
    • Carlo Rating: 11
      • West Yorkshire
    Historically, APEs and rolling roads don't go together.
    Weekdays: Campovolo A500
    Weekends: White AGP SS
    Offline adam1234
      • wales
    why not ?
    Offline sandys
      • Bristol
    They run fine on the rolling road, you run them on the dyno for a  minute or so with computers complaining then they all disable, you can them flick it in sport and run at your leisure I have run loads of times.
    Offline adam1234
      • wales
    OK thanks so its best to run it normal for a bit then after a few minutes put sport on ?
    Offline sandys
      • Bristol
    It doesn't matter the mode, when you put it on the rollers it will complain, it won't accelerate, it'll be generally unhappy due to computers seeing front wheels move without rear, computers will give up after something like a minute assuming a fault and then 6 or 7 safety systems will disable throwing up warnings, now it will run.
    « Last Edit: February 19, 2013, 10:12:48 am by sandys »
    Offline adam1234
      • wales
    OK so its fine to put it on a dyno thought ye  :thumb:
    Offline sandys
      • Bristol
    Yes, when you drive on a normal road again the computers will be happy and all warnng lights will go away, that has been my experience.
    Offline M5/Abarth Russ
      • KENT
    When I have my BMW M5 dyno'd, I have to pull the 2 fuses for the traction control and the ABS otherwise the computers put the car in limp mode.
    Its because you cannot completely turn of these systems and I expect the APE needs something similar before it will run full power on the rollers.
    2011 Abarth Punto Evo EsseEsse
