Author Topic: how much are brake pads for APE  (Read 2095 times)
Offline adam1234
    • wales
« on: March 05, 2013, 03:11:29 pm »
hi all  :wave:
i need new brake pads on my APE was just wondering how much they are
any replies much appreciated :thumb:
    Offline Andrew
    • Carlo Rating: 11
      • West Yorkshire
    Re: how much are brake pads for APE
    « Reply #1 on: March 05, 2013, 07:45:01 pm »
    OEM or aftermarket?
    Weekdays: Campovolo A500
    Weekends: White AGP SS
    Offline Gary Miles
    • Carlo Rating: 4
      • Corby
    « Reply #2 on: March 06, 2013, 07:44:21 am »
    Hi Andrew, what is the difference? ???
    Offline adam1234
      • wales
    « Reply #3 on: March 06, 2013, 11:00:41 am »
    At a guess I would say its OEM as its just at a garage and they did not say a brand name, what have you used in the past and where from ?
    « Reply #4 on: March 06, 2013, 11:04:06 am »
    i ,ve only ever used Abarth ones, 140 quid for SS ones but cheaper for standard car :thumb:
    Offline adam1234
      • wales
    « Reply #5 on: March 06, 2013, 11:24:50 am »
    whats a good website to get them from ?
    « Reply #6 on: March 06, 2013, 11:29:08 am »
    e bay might have some, dealer is most reliable source :thumb:
    Offline Gary Miles
    • Carlo Rating: 4
      • Corby
    « Reply #7 on: March 06, 2013, 11:36:22 am »
    Thanks Lloyd as always :thumb:
    Offline adam1234
      • wales
    « Reply #8 on: March 06, 2013, 11:41:51 am »
     :thumb: Thanks
    Offline GreyApe
    « Reply #9 on: June 15, 2013, 01:06:28 pm »
    My pad warning light has just come on as I parked on the drive.
    No 'local' dealer can take on the job for two weeks (has to be a Saturday).
    A difficult question to answer....
    Has anyone experience of how many miles I have before disaster strikes?
    I do dual carriageways and will drive very carefully over the next two weeks  :angel:....
    1000 miles seems to be 'web wisdom' for other marques - there's about 3mm+ left on each pad.
    « Reply #10 on: June 15, 2013, 05:16:57 pm »
    the front pads on the Brembos are one of the easiest DIY jobs ever, give it a try
    remove wheel, knock pins through calipers with a hollow point punch, remove spring, remove pads, press pistons back into caliper with a flat piece of metal/wood, check fluid doesn't overflow from reservoir, insert new pads and put it all back together :thumb:
    Offline GreyApe
    « Reply #11 on: June 15, 2013, 05:59:49 pm »
    Thanks Lloyd, I am tempted. In my youth I did all my own repairs/servicing so have done everything from changing pads to engine & gearbox rebuilds. Age and a demanding job have made me a bit 'lazy' as far as car DIY concerned.
    No excuse. Should give it a go.... ::)
